basically I only drive in gears two and three from 0 to 55mph or so
If I'm in that speed range I keep it in only those two gears.
That's seems to be the best technique for sound. With exhaust open obviously.
Still deciding between dynamic or regular mode though when doing the above. I like the smoother ride of the non dynamic.
Even my base V6 loses traction in the first 3 gears when starting out with moderate throttle on cold tires. Once the tires are heated, they stick well, except when really hammering the throttle on launch. It's also harder to get them heated up in the cooler months. Most such tires carry recommendations not to use them in temps below 40ºF or so, but they still must heat up even when the temps are above 70ºF.
If you ever watch any racing series, you might have noticed that when drivers pit and change tires under a yellow flag, they spend a lot of time zig-zagging the car around trying to heat up cold tires prior to a green flag re-start.
