Battery charging issue /Help!
Battery disconnect involves removing the negative lead from the battery for half a minute or so. That resets any modules that have been locked on by the use of the OBD port. It's a known quirk, not everything you plug into the OBD has the effect but many do. I believe the symptom is that the light stays on in the hazard switch if the problem has occurred - check it an hour after locking the car and if it's on, do the battery disconnect!
Now your battery has gone flat I suspect the modules will have reset already. Battery should be fine after a recharge.
