Battery Disconnected - Trunk Closed - Please Help !!
#61
Ah, you're talking about the trunk lock on an XK! That does have a keyhole behind the licence plate and I think I recall my 2010 XKR had a removable cover on the door handle to reveal the emergency key access. Your handbook should give details.
Kuekuatsu07 (05-06-2021)
#62
#63
#64
About key locked in XJ8L trunk If you look in the back seat, there is a pull-down seat-arm. But it is also a pathway for long snow skis. That means, it is a path to the inside of the trunk! Unless your as thin as a snake or have 6 feet arms, you can reach if you get a push button 'grabber" and a flashlight, with considerable pain and agony you should be able to fetch that key. Good Luck. Let is know if it worked.
#65
#66
We've gone down a rabbit hole here.
There is no key access to the trunk on an F-Type; the XK does indeed have a key access on the driver's door handle under a cover with a key symbol embossed on it. I cannot imagine an owner not knowing that crucial bit of information. And the F-Type also has key access for the driver's door but the door handle must be pulled out to reveal it.
The XK for Canada and the US has a very much exposed key access point for the trunk, not behind the license plate, since our plates are much smaller that the European/UK plates, and finally, there is no rear seat in the F-Type and therefore no practical access from the cabin, even in the coupe version.
I need a glass of wine.
The following 4 users liked this post by sov211:
#67
Our cars are too electronic.
There's too much climate and stereo controls on the touch screen.
My touch screen died on my 2012 XF.
Now i can't set the function and fans.
The trunk is kind of a p.i.t.a. Yes, the little keyfob key pops in that hidden hole,
and it opens the trunk. Still, it's to arduous & fancy for me. Give me regular keys and key holes.
i disconnect my battery because i go away on long trips.
I reconnect it, and my door locks don't work.
CAUTION using your cup holders.
Spilling even a few drops of liquid on the push-button starter/gearbox control/emergency brake module
may result in a gearbox fault. The result may not be immediate, but
you REALLY don't want to get a gearbox fault.
You may forfeit significant hard earned wealth.
Clean with damp rag treated w/ super evaporative/ electronic cleaner fluid only.
#68
JagGuardian (05-21-2021)
#69
THANK YOU ! THANK YOU ! THANK YOU ![Icon Woot](https://www.jaguarforums.com/forum/images/smilies/icon_woot.gif)
I was able to get the trunk open by applying fused 12V to Pin 6 (Black wire) on the C3BP01F connector. It was the best clicking sound I have ever heard !!!!!!!!! I used the backup 12V battery from my garage door opener.
Really, Really, Really appreciate everyone's help and ideas.![Icon Worthy](https://www.jaguarforums.com/forum/images/smilies/icon_worthy.gif)
Special Thanks to DJS and Lizzardo. The info you folks provided saved my bacon.
Love the forum - love the help.
Lessons learnt: Be patient - don't rush. I'm glad I waited till I had feedback from several members before I went applying 12V to random wires on the car. Also, never close the F-Type trunk........ever !!!! If you see a guy driving around a white F-type with the trunk open - it's me.![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
The JAG is purring again !
#70
machi477
72
12-16-2012 08:33 AM
123ABC
01-03-2009 12:10 PM
