battery drained due to OBD port
Old 05-08-2017, 08:31 AM
always's Avatar
Default battery drained due to OBD port
aloha ,
this problem seems like being an issued for a long time
but i am wondering if there anyone who meet up this problem after plugging
manufacturer's obd ?
i had my oil changed in the late Apirl ( in our local JLR dealership ) , then i got this error every morning when i trying to start my car
two of my friends who also owning f type happened to this error after plugging OBD when they upgrading their exhaust system .
Old 05-08-2017, 10:18 AM
DPelletier's Avatar
Yep, common issue. After using the OBD port, disconnect the battery to reset
Dave
AaronLin (05-08-2017)
Old 05-08-2017, 10:39 AM
AaronLin's Avatar
Dave
So Jaguar never fix the problem yet....?
What are the chances of getting the Low Battery Warning after connecting to the OBD port ?
Old 05-08-2017, 03:57 PM
Uncle Fishbits's Avatar
It's generally assumed they will never, ever fix it. They aren't particularly thrilled about people plugging things *into their own car*, but it is true that cars are becoming less "ours", every day. "If you can't open it, you don't own it" is a great line in the computer world, but it's starting to apply to cars. I mean, leasing companies can remotely shut down cars, now. So can cops, in some areas (I believe).
ANYHOO.... that's all to say they aren't going to fix it. It glitches the electrical system into not shutting off the door lock LED and hazard light.
It's a bummmmmmer. But the electrical systems are so complex nowadays, I can't imagine them being able to figure it out, even if they wanted to?
The following 2 users liked this post by Uncle Fishbits:
AaronLin (05-09-2017), gg2684 (10-28-2022)
Old 05-08-2017, 04:02 PM
Burt Gummer's Avatar
Helen Wait is the top technical coordinator at JLR. She will do nothing. Adapt; just about every car has some odd flaw(s).
Old 05-08-2017, 04:27 PM
stmcknig's Avatar
So far, knock wood, I have not run into this OBD issue and I've used a number of OBD scanners and the VAP tuning gizmo. When my car goes to sleep the hazard triangle on the console goes dark...assuming that means all is well ;-)
Old 05-08-2017, 05:59 PM
jaguny's Avatar
Goto H.W. is her full name, I believe.
Burt Gummer (05-08-2017)
Old 05-08-2017, 07:40 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Try as I might, I can't get the energy management module to go wonky. I've tried all combinations of equipment, sequence of plug-in and unplug vs. ignition on and off, but no battery drain issue. For me, the "Jaguar Vehicle Enhancement Program" totally resolved the issue.
Old 05-08-2017, 07:44 PM
always's Avatar
yeah ... looks like they probably can't fix it even if they want or they just don't want people to *** "their car"
However , would be weird even with manufacturer's obd still odds to get this error .
To unhingd :
so where can we get that "Jaguar Vehicle Enhancement Program" ?
i had my computer upgraded already when i doing my oil change in local dealership .
Old 05-08-2017, 08:02 PM
Unhingd's Avatar
Originally Posted by always
To unhingd :
This is what I have:
It's quite possible if the car is leased, some may never see this notice.
Old 05-08-2017, 08:18 PM
always's Avatar
TO Unhingd
Thanks , i will show this to my dealership technician see if i got this upgrade too
I wish it could fix the situation otherwise we have to reset it by chances
so you are all ok with obd which is not from original factory ?
Old 05-08-2017, 08:54 PM
Unhingd's Avatar
Before, every time I attached a data logger or handheld tuning device, the battery would drain sufficiently by the next day to cause a low battery alarm. You can tell quickly whether this will occur if the hazard warning switch remains lighted for more than 10-15 minutes after you shut down the car. Since the "upgrade", I have experienced no such issue.
dwmilton (05-30-2020)
Old 05-08-2017, 10:39 PM
zmoothg's Avatar
I'm jealous. I have an appointment tomorrow to address my fault AC compressor, I'll see if they can do this while they are at it. I have a Navdy HUD system that requires the OBD port, maybe I will finally get to use it.
Old 05-09-2017, 03:04 AM
always's Avatar
thx , very useful !
Old 05-09-2017, 09:00 AM
Desert Hiker's Avatar
My service manager is researching to see if the Vehicle Enhancement Program can apply to my 2015 F-Type S. Just purchased an OBD2 scanner for fun and on-the-road quick Dx/Rx................
Desert Hiker
Old 05-09-2017, 10:29 AM
always's Avatar
the recall letter did not sending to all owners at the same time causing us so many confused during this time .
some overseas dealership may not even know this at all .
Old 05-09-2017, 11:40 AM
zmoothg's Avatar
Does anyone have the TSB numbers.
Old 05-09-2017, 12:03 PM
Unhingd's Avatar
I believe this is the relevant one: SDD149_03_V267J_V3 (software update 149_03)
Old 05-09-2017, 02:11 PM
zmoothg's Avatar
I referenced your number to the dealer today. They stated:
"I let my foreman know about the OBD update. It looks like the software you referenced is for our Jaguar/Land Rover diagnostic computer, and not a software update for a vehicle. I’ll definitely keep you in mind when I see any news from Jaguar."
Old 05-09-2017, 06:09 PM
I've got this. Excited.
So other than whatever this is, what else *could* be updated. I could pay for the maps update (nope), ask if there's been a stereo update (but if it ain't broke.....)
Or should I just assume a formal notice like this is literally a massive update to the car, and I should just go with that?
Will it alter the cars joy joy in any way?
