battery drained due to OBD port
I've got this. Excited.
So other than whatever this is, what else *could* be updated. I could pay for the maps update (nope), ask if there's been a stereo update (but if it ain't broke.....)
Or should I just assume a formal notice like this is literally a massive update to the car, and I should just go with that?
Will it alter the cars joy joy in any way?
Looks like someone is going after Jaguar. Someone should take them to court for the OBD problem: http://gotaclassaction.com/wp-conten...uar-3-1-17.pdf
By way of "loss incurred" he claims Diminished Value. Yet he is leasing his 2016 Xf so he isn't going to experience any DV - that's going to be Chase or US Bank.
And nothing about OBD gremlins that I could see.
But I suppose on the bright side I might get a check from Jaguar for 32c
No...you can use it as often as need. Just reboot the module every time you do.
Hi Unhingd
is there any method to reboot by ourselves easily ?
i had to bring my car back to dealer to reset and charging battery , cost me many time on that
anyway i don't dare to plug any obd2 now ... i recently set up my new exhaust , it need an obd2 to detect rpm in order to contorl the valve .
now i just leave it unplug
thanks for you help above
Originally Posted by always
Hi Unhingd
#28
#30
#31
#33
No, I did not. I carefully reviewed with them before hand what they were going to do and made certain they were not going to flash the ECM. To be safe, though, you might want to temporarily flash back to the oem file.
zmoothg (05-20-2017)
#35
They confirmed there was no engine upgrade to be done. I had already had the O2 upgrades done before I started tuning. If they had wanted to flash the ECU, I would have reverted to the OEM tune, let them do their thing and then worked with VAP to overlay my current performance tune on top of the new OEM tune.
#36
I guess I need to tell them to redo the update ?
#37
#38
This is great information for the future. I think my car needed a 2nd O2 sensor update (K433) which they did last week. My car was at OEM tune when I took it in, after I received the car back, I put back on the VAP tune, I guess I basically undid the updata.
#39
.+1. You'll probably have to send the handheld back to VAP so that they can wipe it to enable you to download the new OEM file. Check with Stuart.
#40
If you have received the "enhancement letter" updates, this may no longer be an issue for you. Those updates resolved the issue for me.
