Battery Unhooked, trunk closed...amateur hr.
Messed up.... unhooked the battery from the busbar in the trunk searching for another issue (no start)... Found a bad mega fuse, great... Until I let the truck lid close (1st Latch, not 100% closed). Any ideas on getting back into the trunk? I can't do the typical hook up with jump point and let the battery charge for two reasons.. First bein the battery is not hooked to the main (+) busbar in the trunk, and ever worse the front jump point is also not hooked to that same busbar because the fuse is blown. I don't know of any other way to supply power to that busbar I can access from the outside? But I can't be the only person who has done this...
2015 Vert
2015 Vert
Received 3,259 Likes
Crowbar?
Seriously though, have you tried raising the trunk lid manually?
You never know the first latch/catch might release or maybe you can poke a screwdriver in there to release it, and pull the lid up by hand.
I know I can raise or lower the hatch on my coupe manually even though it has the power operation option.
I forget....you have a vert or a coupe? Any way of snagging the emergency release with a long hook from inside the cabin?
Good idea, going to try this later today with some of the other main (+) leads to the front fuse boxes. Could work in theory!
So this is on my list of options also, I do have an emergency release on the rear face of the trunk next to the Latch area but I will be completely blind tryin to hook on to it. Still better then a crowbar.
Why did your fusible link fail?
Itismejoshy (05-26-2019)
Sorry to revive this old thread; went to the known issues sticky, could not find a write-up. I need to power the trunk release and I was hoping to get some more details or pictures on what exactly needs to be powered and where a good ground would be. I see that this is a fuse panel, appears to be driver side (USA). In this pic is the red lead (not jumper) connected for ground?
