Before & After: Velocity AP Lowering Springs (7/8") and Hub Centric spacers (17mm)
Also, like you, it seems to me that the new MPS4S fill out the wheel wells just a little bit more than the old P-Zeros did. I don't think this is down to new MPS4S vs old/worn P-Zeros, as in my case the P-Zeros were hardly worn at all on the outside edges while the inside edges were bald.
Greggbhill (09-03-2017)
This has been covered a few times, no effect whatsoever on the active/adaptive suspension, even with the substantially lower H&R springs.
Lowering your car will make it less comfortable by making the overall ride harder. Additionally you also have less clearance (space under the car), so navigating around speed bumps, sloped driveways and underground garage ramps becomes challenging.
There are plenty of options: VAP, H&R, Eibach and they all lower the car slightly differently.
As others have said, true progressive rate springs (like the VAP ones with a tapered diameter coil) minimize the impact on ride quality from lowering the car. Doubtful most drivers would notice any effect from a 7/8" drop in terms of ride comfort on straightaways. However, as others have noted, the visual improvement of lowering springs and spacers is profound and is well worth it. IMHO.
