Best AWD R Launch Strategy
Tried to continue this in another thread, but it's been closed.
Question: what's the best set-up for launching an AWD R in dry conditions?
Dynamic mode on seems like a given, as does in sport mode, but:
* Sport auto OR sport manual (paddles)? My understanding is the computer starts you in 2nd when activating sport auto from a standstill; can you force it to 1st without using the paddles? Is one (1st vs 2nd) better than the other?
* DSC on OR DSC off? (will restate that we're assuming dry conditions here)
- if OFF and tires begin to slip, modulate throttle or keep it buried and let the front wheel assist handle it
* Pre-launch RPMs flat, 2K, or 2.5K?
* Bury the pedal or ease onto it until you feel solid grip then bury it?
Haven't run the car at a track and don't have Dragy or VBOX, so not able to test all of these variables on my own.
Thanks,
Rick
Thanks,
Rick
Received 3,208 Likes
I have never ever used rain/snow mode and I doubt I ever will so I don't know what difference that makes if any, but I remember reading somewhere on here about a FM who achieved his best 1/4 mile times by using rain/snow mode! I think it was in an XFR or maybe an XFR-S.
This has been debated at length across several sub-forums involving Jags that use the ZF 8HP70, but as far as I can figure out it starts in 2nd gear by default but if you bury the right hoof on take off it kicks back to 1st at around 4,000 rpm. If you ease the go pedal down to the floor taking around two seconds (instead of slamming it down) then it may not kick back to 1st.
I can say definitively that on the 5.0L XKR with the 6spd. ZF, it starts in 2nd gear and defaults to 2nd when you come to a stop, And if you have it in dynamic mode, you will see the big circled 2 on your dash showing this. I would assume the 8spd in the F type does the same thing.
I wish someone would do the same with an F Type to confirm once and for all rather than people presuming. If I ever get round to buying an F Type I will do the test for myself but for now here is my '10 XKR in drive and you can see it drop in to 1st each time I come to a halt:
SinF (04-03-2020)
Best way to launch is off idle in my opinion; this is the way I've got my best quarter mile times. Don't raise the RPM and just smash the pedal. It's a shame we can't brake torque the thing without the ECU pulling torque from us, but I assume that's Jaguar trying to save the transmission.
SinF (04-03-2020)
1. TracDSC (hold button down for about 3secs)
2. DSC fully off (hold button down for about 10secs)
For those on here with the best times, I’m not sure which setting they used. I usually run TracDSC and run up rpms to ~2000-2200 and that’s been good for 3.3s. If I don’t build up the rpms, my times are consistently 0.2-0.3secs worse to 60.
Here is how I ran my best time when stock (11.554 @ 120.44):
I am hoping the weather will be nice enough on Sunday to get out and do some logging runs to check my latest tune from VAP. I will also try to capture some launches using the above method to see if I can answer the question of what gear the car initially launches in. 1st vs 2nd gear as the launch gear has always puzzled me, and I haven't found a clear answer in the forums. I know the car only downshifts to 2nd gear on its own when coming to a stop in Sport mode and using the paddles. I will try to find out for sure what happens in Sport mode and letting the car do the shifting.
- Dynamic Mode
- Sport mode for transmission
- Traction control completely off
- Automatic shifting (not paddles)
- Launch from idle
- Dynamic Mode
- Launch from idle
Hi,
your diff from OEM to Stage 2 is in my view to small.
2016 R Coupe AWD
11.63 @ 121 (stock)
11.01 @ 126 (lower pulley + tune)
My 2017 R AWD have following diff, but sorry only in km/h
0-200 km/h 12,5 sec.(stock)
0-200 km/h 10,60 sec. (Stage 2)
round about 2 seconds! All times measured with P Gear 610 and same temperature and same road section
not sure but I think it was about a 1/4 mile, about 400 yards. As I said, I have to check again, unfortunately
I don't have the old smartphone anymore and I didn't save it to the cloud. I can remember the times well, but not the meters driven!
I will test this with Stage 3 in 2-3 month and i come back with new times and alo i will test 1/4 Meile...
Andi
2016 R Coupe AWD
11.63 @ 121 (stock)
Andi
That’s impressive. And weirdly I never see better times launching off of idle, despite what you and others have observed…two schools of thought I suppose. I know there’s a margin of error with Dragy, but on average my idle launches get me to 60 0.2-0.3 seconds slower than when I run it up to ~2k rpm. Not sure how but maybe I’m managing to screw up just hammering the pedal lol
Hi,
2016 R Coupe AWD
11.63 @ 121 (stock)
2016 R Coupe AWD
11.63 @ 121 (stock)
