Best Dash Cams for F-Type
#102
#103
#104
You are correct. There are excellent choices for $100-$120 that have it all. I picked this one and have had it in two vehicles for 6+ months and its pretty much rock solid.
It fits in behind the passenger side of the rear view and does/has everything anyone could want for less than $120 (with the excection of REAR view, which in that case I'd go Blackvue).
https://www.youtube.com/watch?v=7OPrYBWCAYc&t=711s
#105
I don't like the Roav Wi-Fi is to slow to connect to download a video and after to copy info the iPhone
and also the function of speedometer g force and other are only on the smartphone you cant salve video with it
prefer another model like viofo for physical button and better video quality and for the sd slot that is important
because if you do accident the first thing you can remove sd from the cam easy
with roav is impossible because is on the top
#107
Hello, i want to get a blackvue front and rear camera system.
i am told the front is no problem fits in great but i am told i can't do a rear camera because of my car being a convertible.
Anyone no how to mount a REAR blackvue camera on a convertible? am told the camera is not weather proof so it has to be mounted inside and obviously with top down won't work and would be in the way of top closing. Any suggestions?
Thanks in advance. Mitchell
#108
#109
The following 2 users liked this post by ek993:
Burt Gummer (02-24-2018),
vettegood (02-23-2018)
#110
from the dashcam mounted to the windshield, tuck the wires in under the headliner until you get to the door, then pull the weatherstripping rubber from the door and it exposes a track where numerous wires are probably already running in. Just tuck them in there and push the ruber back n place.
#111
Can anyone help me out? I have the VIOFO129, dual camera system. For the parking mode to function, the power cable, running down the A Pillar needs 12V constant and 12V switched accessory, meaning it goes hot when the ignition is activated. Every fuse in the passenger compartment is 12V Constant. I cannot find anything on the Accessory side. Am I doing something wrong in testing with a test light?
#112
You may find some of those constant live shut off after ten minutes or so once the locked car goes to sleep. Look up the fuses for the accessory power socket (cigarette lighter in old school). I thin those are the ones I used for my Blackvue Power Magic which also wants a switched and constant feed.
Arizona Ranger (05-19-2019)
Uncle Fishbits (11-02-2020)
#114
XxSlowpokexX
11-17-2015 12:22 PM
