blackstone oil report (first of many)
Old 10-12-2015, 10:26 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
I suspect that Stohlen's comment was just a metaphor.
Everybody thinks they're riding their beasts hard and putting them away wet. In truth, I don't care who you are, your driving privileges would be revoked it you were really punishing the car as on a race track. You're not.
I'm with Stohlen . . . a lot of people waste a lot of money for no good reason.
Old 10-13-2015, 06:44 PM
Stohlen's Avatar
Yes, you are correct. Obviously I don't mean for someone to go put gear oil in their engine or something like that. My point was rather that any name brand 0W-20 full synthetic oil is going to suit the vehicle just fine. We replace the oil because of contamination prior to using up the additives in the oil, so it really doesn't make any difference on if the oil meets a relatively arbitrary specification from an engineering perspective. Any standard oil is going to be close enough to OEM specification as long as it is name brand, and additive requirements change as the engine ages anyways so that's really a moot point.
Old 10-14-2015, 09:05 AM
DJS's Avatar
DJS
DJS is offline
Received 2,112 Likes on 1,410 Posts
Based on the printouts I've gotten from my Jag dealer, they haven't used whichever Castrol it is that meets the JLR spec on my two oil changes so far.
Old 10-14-2015, 09:41 AM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
What did they use?
Old 10-14-2015, 11:02 AM
DJS's Avatar
DJS
DJS is offline
I'll have to revisit the reports. One was Castrol Edge (but not Pro), the other was a different Castrol.
Old 10-14-2015, 11:13 AM
TXJagR's Avatar
My dealer no longer stocks the OE (gold bottle) and I was told that Jaguar sends them the regular Castrol Edge (silver bottle)
Old 10-14-2015, 02:29 PM
speedhacks's Avatar
I found the following from Castrol's website.
http://oilselector.castrol.com/c/uk/...SC-%282014-%29
It says refer to dealer.
If you do a google search you'll see all over that JLR endorses Castrol Edge "Professional."
https://www.jaguar.com/about-jaguar/castrol.html
Personally, I've never worn an engine out / had any catastrophic problems due to incorrect oil usage and find that it would be hard to pin it down to not using a specific oil.
I suppose next oil change I'll get will be 7,500 miles later and see what the TBN is on it.
Is it pointless to do the TBN test on it without having a virgin oil sample to compare to?
All that garbage aside, it would be nice not having to spend $200.00 for an oil change so often.
  #28
Old 10-15-2015, 10:39 AM
lizzardo's Avatar
According to Blackstone, the TBN needs to be over 1.0. My sample at 518 miles measured at 6.4. It's hardly a virgin sample, as those were 518 miles of break-in. With my C30, I only had TBN measured some of the time. Initially, I was trying to determine what the proper change interval was for my usage. One of the tests showed TBN down to 2.4 at 5K miles, but that was still looking OK for 7.5K. Once I confirmed that the factory recommendation was acceptable, I was less concerned.
The recommended change interval for the F-Type is one year or 16,000 miles. I typically run about 15K a year, and I have never gone that far between oil changes.
This is the first car I've owned that did specify a break-in procedure, but did not specify a break-in service. My plan at this point is to change the oil soon, then monitor it over the year, perhaps every 5K miles. I want to get a feel for how heavily the oil gets stressed.
Old 10-20-2015, 07:22 AM
Unhingd's Avatar
I am sending two samples of oil off to Blackstone today (0 miles and 3750 miles). With the 0 mile sample, we will at least have a baseline against which to compare all other samples using the OEM(recommended) oil.
  #30
Old 10-20-2015, 10:22 AM
lizzardo's Avatar
This is my 518 mile sample:
  #31
Old 10-20-2015, 03:10 PM
Unhingd's Avatar
Given the fact that the bottle advertises "Titanium Technology", there is no wonder why the titanium levels have been high on the samples recorded to date.
  #32
Old 10-29-2015, 07:48 PM
Unhingd's Avatar
Lizzardo,here's mine at 3768 miles. Not surprisingly, very similar.
  #33
Old 10-29-2015, 08:27 PM
TXJagR's Avatar
FWIW, my father used to have a Ford F350 Turbo Diesel that he towed a rather large travel trailer around the country. He used nothing but Amsoil, and never changed oil until he was told it was time by Blackstone when he got got his sample results back. I remember there were times he was over 20,000 miles before he changed. (Although he did change the filters and top off with fresh oil in between changes)
  #34
Old 10-29-2015, 08:37 PM
Unhingd's Avatar
A solid strategy. I will be analyzing oil and changing filters every 5-6k. Will change oil based on Blackstone recommendation or 18k, whichever comes sooner.
  #35
Old 11-11-2015, 09:36 PM
Unhingd's Avatar
Default Baseline Oil Analysis
For those of you doing oil analyses to monitor for appropriate change interval, you might find the following report useful. It is from a virgin oil sample of the OEM recommended oil: Castrol Edge Professional E 0W-20.
The following 2 users liked this post by Unhingd:
buickfunnycar.com (11-11-2015), lizzardo (11-13-2015)
  #36
Old 11-13-2015, 01:25 AM
plums's Avatar
Received 2,184 Likes on 1,624 Posts
Those 100*C cSt's look awful thin.
  #37
Old 11-13-2015, 05:48 AM
Unhingd's Avatar
For a 0W-20, that's actually just a bit heavy. The spec calls for 8.0 vs the reported 9.35. Still within range.
  #38
Old 11-13-2015, 10:13 AM
lizzardo's Avatar
I'm at about that mileage now, so will pull a sample this weekend for comparison, and also for comparison with my 500 mile sample and your zero mile one.
H.Jones
10-25-2015 07:24 PM
Safari
10-25-2015 10:57 AM
richzak
10-09-2015 05:14 AM
rldvols
10-08-2015 09:50 AM
n8ertot
10-07-2015 08:57 PM
Quick Reply: blackstone oil report (first of many)
