Blackstone oil test results
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/750x952/09bd46f9_b887_40c9_b9e3_2fdeaa36d44e_1e7ee132c3064a5f4a08be2ef02a3efeaca5ba98.jpeg)
About two weeks I had the oil changed at the dealer for my first time. The non-jaguar dealership I purchased the car from back in May said, and reported to Car Fax that they changed the oil prior to sale with 17k mikes on the odometer. I was unsure what oil they used so as a precaution and piece of mind I changed the oil within the first 1k miles of my ownership. I decided to send that oil out for testing and here is the results. Other then the comment section I have no idea what I’m looking for. Anyone care to chime in?
Received 3,226 Likes
About the only thing that report tells me is the dealership which sold you the car didn't use the specified Castrol Unobtainium brew which is low in molybdenum and high in titanium, they used something else.
Dozens of threads and mucho debate about this (does it really have to be Unobtainium?) but IMHO it doesn't have to be as long as it meets the JLR spec, I for one have never used it and never had an engine problem yet.
Edit - forgot to add - the high silicone could be from using some silicone sealant on the sump plug, fairly common practice and you need to be extra careful not to get any on the end or threads of the plug.
edit: I’m curious if the silicone reading is due to the dealer extracting the oil sample from the filter housing vs the bottom of the pan. They said their system is set up to extract the oil into a large holding tank with all the other vehicle oil they change so unable to just collect my cars oil. The mechanic pulled the 8 ounces from the filter
Tp10XKR (09-30-2019)
However, the silicone issue needs to be tracked down. The air filters and intake tubing need to be inspected for leaks.
Unhingd hit it on the head, good test results overall. The silicone could be from some work that was done, or the pan bolt, or anyplace that uses sealant exposed to the oil...not a worry item IMO BUT, id drive it a few thousand pull a sample and resend it for a piece of mind if you don't see any obvious causes, and also put the Castrol Edge Professional OE 5w-20 or 0w-20 or the new LIQUI MOLY JLR spec (what i have been running) in it.
The following 2 users liked this post by Queen and Country:
Itismejoshy (10-01-2019),
Tp10XKR (10-02-2019)
The JLR spec calls for high titanium, so whatever was previously used was not a JLR compliant oil. No matter, a couple thousand miles with inadequate titanium is a non-issue.
I have replaced the air filters on my F-Type and I didn't see any hint of silicone anywhere. Rubber, plastic, paper (air filter elements) yes but no silicone.
I have read on some other thread around here, pretty sure it was in the XF section and was about an XF SC or XFR, of a FM who found the air filters had been "glued in" to the air boxes with some sort of adhesive/sealant which could possibly have been silicone sealant. I reckon that was extremely non-standard as I replaced the air filters on my old XFR twice and once on the F-Type and in all cases no hint of any adhesive, the filters just lifted/dropped straight out of the air boxes.
Or are you suggesting Lance that the orange rubbery surrounds of the OEM air filters are silicone or silicone/rubber and not just rubber, and maybe some pieces or even chunks have broken off and ended up in the combustion chambers and from there into the oil?
The silicone doesn't come from the hoses/pipework or from sealant, it's from a leak in the intake system allowing unfiltered air into the engine which then contaminates the oil. The silicon is in the air (dust). At least I think that is what Blackstone is saying.
What if the silicone came from the dirty hands of the mechanic extracting the oil from my car? and as noted he told me he pulled the sample from the oil filter housing and not the pan...or the dealership who did the “free” oil change before selling me the car who knows what oil they even used in it. Blackstone’s report doesn’t tell me the type or grade of oil I submitted.
I’m going to check my intake ducts but I’m not very concerned at this time, and next summer when the oil is changed again, I will Compare the two for contamination. Jaguar put in Castrol Edge Professional spec 5W-20.
PS. My other half has had “work done” but they don’t use silicone anymore.....saline boys. Lmao
Maybe from the oil filter housing or the filter itself but it's hard to see how they got 8 oz that way as the filter is damn near empty when you remove it, I reckon they must have got it some other way. There is some residual oil left in the canister housing (the bit the canister screws into) after you remove the canister but still nowhere near 8 oz.
The plot thickens!
Edit - also see this page: https://www.machinerylubrication.com...con-engine-oil
I figured you would catch on eventually.
This is as confusing as an ancestry test.
Silicon is a byproduct of the direct injection combustion cycle, the biggest one. But what does that mean?
"silicon and ammonium sulfate were the dominant emissions. Elements present in lubricating oil (zinc, calcium and phosphorus) were present in all samples at very variable amounts, probably depending on the consumption of lubricating oil."
"it's hard to see how they got 8 oz that way as the filter is damn near empty when you remove it, I reckon they must have got it some other way. There is some residual oil left in the canister housing (the bit the canister screws into) after you remove the canister but still nowhere near 8 oz.
The plot thickens!"
This is just what I was thinking. When i removed the oil filter not a drop of oil came out from the housing. Hmmmm
The plot thickens!"
![Icon Verzsilly](https://www.jaguarforums.com/forum/images/smilies/icon_verzsilly.gif)
