Blackvue Dashcam install
Old 03-04-2016, 06:09 PM
RawwR's Avatar
Default Blackvue Dashcam install
I've wanted to install a dashcam for months but have not due to headliner issues. I thought the headliner issues wouldn't return so I purchased the dashcam. Well I said screw it and installed the dashcamn today. The following photos show how I routed the wires. A few things I would do differently. Blackout the white writing on the front dashcam bracket, get a larger crimp ground ring, and ensure the heating elements are not in the middle of the rear camera. I put some foam spacers on the left side of the battery before I velcroed it down. I hope the pictures are self explanatory. I know the front camera blocks the auto headlight feature but I never use it.
Attached Thumbnails Blackvue Dashcam install-slide1.jpg   Blackvue Dashcam install-slide2.jpg   Blackvue Dashcam install-slide3.jpg   Blackvue Dashcam install-slide4.jpg   Blackvue Dashcam install-slide5.jpg
The following 2 users liked this post by RawwR:
Orkney (03-04-2016), Smoke Em (04-10-2016)
Old 03-04-2016, 08:01 PM
Nati's Avatar
did you take the power supply cord from the front camera unit back to the trunk? Did you just go along the driver's side taking the same route?
Old 03-04-2016, 09:39 PM
RawwR's Avatar
Both cords run along the passenger side, they split were I hide the rear camera excess cord. The power cord continues into the trunk.
Old 03-05-2016, 09:20 AM
Nati's Avatar
Awesome. What is the cellink box for and is that part of your install?
Old 03-05-2016, 01:42 PM
RawwR's Avatar
Cellink is a separate battery for the camera to run on so it doesn't draw any power from the cars battery. Its a complete package from blackboxmycar's website.
Old 03-05-2016, 05:31 PM
Nati's Avatar
Oh cool. I was always worried about running one of these cameras off the car's battery when parked. I know they sell devices that cut the power when the battery drains to a certain threshold, but with the electrical gremlins some have reported with this car, what you have looks to be a much better solution.
Old 03-05-2016, 08:13 PM
TwiztOG43's Avatar
I thought about getting the battery, but the PowerMagicPro works flawlessly. Haven't had a low battery issue since I have had it.
Old 03-06-2016, 02:18 PM
ioneabee's Avatar
Old 03-06-2016, 04:35 PM
CaptainHam's Avatar
I just fitted my Blackvue to the left of the rear view mirror (or right in your case as mine is RHD), ok it's not central but it's close enough and you still get a full view out of the front.
In this position, you can't even see it from driver's eye view as it's completely hidden behind the mirror...doesn't your positioning detract slightly from the already limited visibility when trying to look out past the mirror?
Old 03-06-2016, 04:52 PM
RawwR's Avatar
If you're asking me, no I can't see the camera at all.
Old 03-11-2016, 04:42 PM
RawwR's Avatar
Low battery issue popped up while the car was at the dealership all week for another attempt to fix the headliner. Dealership says the Cellink was not letting the car go to sleep. I have removed the tap a circuit and moved the positive to the eco-battery.
Old 03-11-2016, 05:15 PM
LobsterClaws's Avatar
How is it for passengers? Is it very noticeable for them?
Old 03-11-2016, 06:26 PM
RawwR's Avatar
The location I have chosen is slightly noticeable to the passenger but its not blatant in direct view.
Old 03-11-2016, 08:54 PM
TwiztOG43's Avatar
I was thinking about that location as well, however from the outside it is very noticeable, and almost looks like its in the middle of the windshield, which is why i mounted mine higher, right behind the mirror on the left side.
Old 03-11-2016, 10:06 PM
Nati's Avatar
Well that's unfortunate. So the Eco battery will drain while parked?
Old 03-12-2016, 01:29 AM
RawwR's Avatar
The cellink is rated for 72 hrs in parking mode and takes one hour of driving to charge. It should not drain the eco battery if you drive enough. By attaching to the eco battery the car should now go in sleep mode. If you don't drive the car enough at least the main battery will still start the car.
Old 04-10-2016, 09:41 AM
Nati's Avatar
RawwR,
How is the revised setup working out?
Old 04-10-2016, 06:24 PM
RawwR's Avatar
I've been out of the country for a couple of weeks however since I've wired to the Eco-battery there's been no issue.
Old 05-25-2016, 04:03 AM
ronniet's Avatar
the fitment at the rear to be honest is very messy and too many exposed wires
Old 05-25-2016, 05:00 PM
MiamiFtype's Avatar
Wow! Great camera, I had no idea this existed. I am actually interested in a camera for the car but mainly for break ins etc. Wish they made one that had 360 view inside the car.
Quick Reply: Blackvue Dashcam install
