Blind Spot Monitor Freeze-up.
Old 04-08-2016, 07:12 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Question Blind Spot Monitor Freeze-up.
Has anyone had the blind spot monitor freeze up on them (steady orange led dot in each exterior mirror)? Mine remained that way for the entirety of the trip, and became functional again after the car sat for a couple minutes with the ignition off.
Old 04-08-2016, 08:01 AM
SinF's Avatar
Received 2,141 Likes on 1,461 Posts
Not yet. So far it worked spectacularly well. I especially like "fast approaching from behind" warning when it blinks at you. Don't judge, I am still breaking it in.
Old 04-08-2016, 08:17 AM
Orkney's Avatar
Yeah, I had it happen once. Same condition where powering down the car and then starting again cleared the error. It has not re-occured since.
Orkney
Unhingd (04-08-2016)
Old 04-08-2016, 09:43 AM
Dogbreath!'s Avatar
Never. In fact it's a great feature. With the top up, this thing has tremendous blind spots. I'm one of antiques that was taught to actually turn my head and look before merging or changing lanes, but in this car pretty much all I can see is black fabric.
Old 04-08-2016, 01:55 PM
xdave's Avatar
I've only had that happen once that I am aware of, and it was when I jumped in the car and wacked it straight into drive after starting and pulled off (I was trying to be as quiet as you can in an F Type, and leave the area before the curtains started twitching!) I wondered if it was an electrical loading issue while various modules were still booting up? I know with both my X350s if I pull away before the touch screen has initialised then the blueooth phone module won't initialise until the car is restarted. Sometimes the radio switches from the amp driven mode into the basic head unit mode as well. Interestingly the X-Type doesn't do it, and it shares the same telematics system as the X350.
I've hooked the F Type up to SDD since then and no codes were logged for the BSM so I won't get worried its broken unless it starts doing it frequently.
When I first got my F Type I found the rear corner visibility utterly terrible (coupe) and used the BSM a lot, but now I've got used to driving it I barely use it as actually its not quite as hard to see the blind spots as you initially think. I do love the rear collision detection though when carefully backing out of a blind parking space. It has a decent range on it too - about 50 yards which gives loads of warning so you can pull back in safely to let cars past. It's one of those things I would always specify on a car now I've tried it.
Old 04-08-2016, 02:02 PM
F-typical's Avatar
Try some de-icer on the mirrors...
Old 04-08-2016, 02:31 PM
Unhingd's Avatar
Thaaaank youuuuuu!
Old 04-08-2016, 02:35 PM
lizzardo's Avatar
I had it happen on my previous car a few times. It used cameras for detection and certain lighting conditions would send it out to pasture. The dealer flashed updates to both DDU and PDU and that issue went away. Not sure where the smarts for that live in the F-Type, but there may be an update. I asked if there were any updates when I took mine in, but there was nothing at the time.
Old 04-11-2016, 05:11 PM
postmachina's Avatar
YES! Mine have started doing this last month repeatedly. An error will come up on the dash as well that I'll have to click OK for it to go away. I can say it happens every other time I'm in the car for longer than 15 minutes.
Old 04-11-2016, 05:45 PM
Unhingd's Avatar
Since last Friday, I've had no issue. When this did happen on Friday, it presented no error message. If you take it in for service, please let us know what transpires.
Old 04-28-2017, 03:42 PM
Mueller's Avatar
I want to revive this thread as the blind spot monitors on my car always seem to be inoperable. The conditions when it occurs: Highway speed, after 4 miles of driving. Occasionally, on really long trips, it will randomly become available again. I have taken it to the dealer and they could not replicate the problem, but of course, as soon as I leave the dealer and hop on the interstate home, BOOM the blind spot monitors are unavailable. Thankfully, I have learned how to drive the car to get around not having them working (accelerate before changing lanes). But having a huge yellow triangle in the dash is unsettling. Anyone having this problem or had this problem repaired?
andrew lowe
UK & Eire
05-06-2016 01:57 PM
LnrB
04-13-2016 10:23 PM
NJ2003XJ8
04-12-2016 05:12 PM
LobsterClaws
04-07-2016 07:29 PM
NaplesTopLess
04-07-2016 07:14 PM
Quick Reply: Blind Spot Monitor Freeze-up.
