Body rocker molding protective plastic sticker
Hello everyone,
Question on the body rocker molding, there is a piece of protective plastic to prevent stone chips.
Refer to the link
https://www.jaguarpartsunlimited.com...r-trim-pillars
Is that stick #7 on the link ? $70 each ? Wow!!!
Thanks, TGX
Refer to the link
Thanks, TGX
Hello everyone,
Refer to the link
Thanks, TGX
Refer to the link
Thanks, TGX
The part numbers are T2R11830 and T2R11829 for the left and right, respectively. To remove the old one, just apply heat with a hair dryer and peel it off.
Jklad (06-03-2019)
It’s really best to cover the entirety of the rockers in PPF if you can. They take a beating. Mine are already showing irreversible stone wear on the leading edges on both sides behind the front wheels and all around the small OE stone guards, even at just 23K mi. Might eventually have mine re-sprayed and will do this.
Hello everyone,
Refer to the link
Thanks, TGX
Refer to the link
Thanks, TGX
