Brake Rotor Dimensions?
Received 3,209 Likes
Performance brakes (standard on the base F-Type): 355 mm front, 326 mm rear.
High Performance brakes (standard on the F-Type V6S): 380 mm front, 326 mm rear.
Super Performance brakes (standard on the F-Type R, SVR and F-Type V8S): 380 mm front, 376 mm rear.
High Performance and Super Performance brakes are/were optional on both the base and V6 S.
Not sure about the 400S but I think it came with the Super Performance brakes stock, and I think the 4 potter (300PS) comes with the "base" Performance brakes stock.
Carbon fibre matrix (CCM) brakes (optional on all F-Types): 400 mm front, 395 mm rear (I think!).
Of course these are the brake rotor diameter measurements, I can maybe dig up the thicknesses later. Also, some specs quote 325 mm for the base rear brakes rather than 326 mm.
We just completed a group buy of custom rotors from Wortec. If you have the super performance brake option (380 fronts, 376 rears), they can build lightweight 2-piece rotors to your specifications.(+/- slots, +/- holes, hat color, disc color, round/sunburst)
They are front (380 mm diameter): 36 mm / 1.42", rear (376 mm diameter) 26 mm / 1.02". Also note that the braking face on the rears starts a fair way out from the hub, ie there is a big gap, but I don't have the measurement for that gap to hand.
I'm pretty sure that to get a custom set made you would need to give them a set of the stock rotors to work from (or they could get a set themselves) and just the measurements won't be good enough.
jeremiahjaguar
01-17-2013 11:13 PM
rajinder75
10-14-2008 10:42 AM
