Brake Squeal - Help?
Hi guys, anyone experiencing brake squeal? I have a 2020 R and it only has 2,000 miles, the brakes are upgraded but not ceramics. They squeal louder on warmer days but totally quiet on cold days... Looking to see if anything I can do before going to the dealership. Any tips would be greatly appreciated, thank you.
Carbuff2 (03-05-2020)
scm (03-06-2020)
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/20200302_162613_f8f232efce4d1098bd1748fe188562f946538bdf.jpg)
How they should look:
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/20200303_111546_f08ed4f320d22112d095426cef9a62ac875bef37.jpg)
Received 3,226 Likes
The normal fix is to apply some brake grease (high temp ceramic) to the backs of the pads, but if that doesn't work you can try some CRC De-Squeak: https://www.ebay.com/itm/CRC-05080-D...0456407b51c3d9
I used it years ago (not on a Jag) and it worked great, completely eliminated an annoying brake squeal that I couldn't cure no matter what else I tried.
You spray a liberal coating on the swept areas of all the brake rotors, both inner and outer faces, then you burnish it on using much the same procedure as is used to bed new brake pads in - get up to 60 mph or thereabouts, brake hard down to 10 mph, repeat 8 or 10 times until you can see and smell some grey smoke.
Roland M
02-23-2015 11:54 AM
venom_99
67
11-23-2012 12:09 PM
