Brake Upgrade
Auto manufacturers do sometimes use ceramic pads, but the braking system is made larger to compensate for the performance loss.
The best ceramic pads can mimic a quality semi metallic pad in feel, at least on the street. But something to consider, when one drives a car capable of going 180+mph, there may come a time when a single high speed stop is required. Although that sounds easy, it's not. There have been a number of Plaid's overshooting the end of the "high speed run" tests. I don't know of any conventional ceramic pads that excel at this.
Changing the entire brake system on the wheel isn’t something I am at all interested in changing on my “R”. However finding a brand of brake pad that doesn’t coat my wheels in brake dust is very much on my list once the OEM pads need to be replaced. My wheels are royal PITA to clean and brake dust all over them changes the color from a deep black to a dusty gun metal grey color after just a few miles. It is one of the minor complaints I have about an otherwise outstanding performance car.
On that car it was not the pads, it was the fluid (surprised me actually - our track normally fades pads before boiling fluid). In any case, though - to affirm - high speed stops are exceedingly challenging on many facets of OEM brakes.
cujet (12-13-2022)
I am currently on the hunt to re-find a thread about "upgrading" brake pads? I remember reading several members saying that they changed brand of pad or rotor (assuming pad). This change helped reduce the excessive dust. Also reading up on frozen caliber which I believe I have just started to experience on one of the wheels.
I have a set in my garage but have not had cause to install them yet!
Many have had good luck with the Porterfield R4S pads. https://www.jaguarforums.com/forum/f...ations-262585/ They purportedly reduce the dust significantly. Some have reported a downside of a bit less brake torque (i.e. stopping ability) when cold, but not significant as I recall. I've run those same pads as my base rear disk pad on my Factory Five Cobra. They are a very good pad.
Burt Gummer (12-15-2022)
#28
Ftypess (12-18-2022)
#31
#33
I like them, definitely need more pedal travel to achieve higher force braking, but I don't mind that and find it easier to be progressive and not accidently grab a handful of brake when I don't want to.
#35
At my second track event with the F type (the same track my car now approaches 150mph in the back strait), a model S came into the pits in a panic. He had no brakes; his pedal was on the floor with almost no effect. I told him to take a deep breath, drive around the paddock area at some elevated speed over idle but not to risk collision. I tried to explain what boiling brakes was about but he was clueless. I told him that likely once they cool it won't be perfect (there are non-condensable gases that ofttimes are created), but it would be substantially better once they cooled off. Sure enough, he thanked me profusely later because they came back, there was a little sponginess to the pedal but the car stopped fine. I cautioned him not to go back out until he bled his brakes and put in a high temp fluid because it may happen again (he didn't).
Castrol SRF is my go to. FYI...it can go a full season if you track your car....due to its "wet" boiling temp being so high.
#36
Received 3,226 Likes
#37
#38
If Wortec is still making the 2 piece suncut rotors, paired with the Porterfields offer a great alternative to an expensive caliper swap. I find that they shed far less dust and require less pedal than OEM after they are properly seated. On the street I have been unable to reproduce the fade that the OEMs exhibited after a spirited twisty run. And, of course, the 10 lb per wheel unsprung weight reduction offers a noticeable handling improvement.
#39
#40
There’s weight info in the Wortec group buy that Unhingd was part of…
https://www.jaguarforums.com/forum/f...f-type-197525/
inmanlanier (12-28-2022)
