Brake wear Front vs Rear
Just picked up my first Jag yesterday. 2017 F Type R Fuji white convertible with 12K miles. First, this car is AMAZING!!
The only questionable item in the CPO report showed a thickness of 11MM front brake pad, 9MM rear. When I questioned this, I was told this is normal for the car. I've never heard of rears, wearing faster than front on any car. True?
Received 3,218 Likes
There are several theories on why this is but the one I favour is the inbuilt anti-dive system - in a medium or higher pressure brake application the rear brakes bite fractionally sooner and harder than the front brakes. Another theory is the parking/hand/emergency brake on the rear and especially the way it auto applies on some cars and auto releases on most.
That said the front brakes still do most of the work which is why the front pads and rotor swept areas are still a lot bigger than the rears.
And yes new front rotors and pads are a fair bit thicker than new rear rotors and pads, for example the 380 mm front brake rotors are 36 mm thick vs the 376 mm rear brakes at 26 mm thick, and the respective pads at 13 mm and 10.8 mm. Those figures for the 376 mm rear brakes are for the XF and although the F-Type has different pads it has the same rotors so would hazard a guess that new rear pads would be the same or very close in thickness.
Here is a page from my old XFR Workshop Manual showing the brake rotor and pad specs for the XF range:
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1152x648/brake_disc_specs_58200fc89db3d192f780862af09b4e17ba51268d.jpg)
JgaXkr (11-23-2020)
The obvious answer is are cars have torque vectoring so even though you dont know it when going round corners in a spirited fashion
the rear brakes are applying themselves all the time hence why they wear out faster.
When i fitted porterfields this year my rear pads were nearly down to the wear indicator, where as the fronts had loads of meat left.
schuss (11-23-2020)
Having just replaced my stock pads, 11/9mm is fine for these. My rears did wear faster, maybe 2mm more than the fronts. I think I had 4mm on the front remaining and 2 mm on the rear. The wear sensor was starting to rub on the rears but hadn't triggered.
Torque vectoring started in 2016 as an option and was standard in 2019 on all models. Before, it was only available on the R.
[QUOTE=RAWONE;2319503]Just picked up my first Jag yesterday. 2017 F Type R Fuji white convertible with 12K miles. First, this car is AMAZING!!
The only questionable item in the CPO report showed a thickness of 11MM front brake pad, 9MM rear. When I questioned this, I was told this is normal for the car. I've never heard of rears, wearing faster than front on any car. True?[/
All my Audi’s all wear faster in the rear and my F Type R is the same wearing down faster in the rear? Anyone really know the reason?
[QUOTE=MikeW1;2321480]
Mikey, this is normal, read the whole thread for several theories why.
Four possible culprits proposed so far:
1. The rear pads and rotors are much thinner than the fronts to start with
2. Anti-dive
3. Torque vectoring
4. EPB
2. Anti-dive
3. Torque vectoring
4. EPB
