A brief but concerning squeak
I am at 38,000 miles. Has anyone else had a brief chirp-like squeak when accelerating a little harder than mild up-shifting between lower gears?
It's is easy to hear with the top down, but not that loud with the top up. It lasts for a fraction of a second, exactly at gear change. It sounds like its coming from the rear underside or possibly from the middle underside of the car, but its hard to pin down from the cabin. It can be recreated when accelerating a little harder than comfortable and up-shifting, but I think I heard it once when twisting the suspension over a rut with no gear shift.
Things I've tried
Things I've tried
- Added dreaded belt dressing to the serpentine belt just to see if the sound changed - nope
- Lubricated the rear suspension - no change
- Re-torqued the wheel lugs and spacers too 100 ft-lbs, usually I tighten to 92 ft-lbs - no change
- Could still be serpentine belt jolt, but I think the sound is more central to the car
- eDiff or fluid - no leaks, looks brand new from the outside, no other issues
- Drive shaft?
- ZF8?
- Brake pads - which do squeal intermittently
- Suspension bushings - all look fine
RichardCranium (12-13-2019)
I drained my ZF8, refilled, ran the car a bit to mix the fluid in the torque converter, drained again, changed the pan which included a new filter and magnetics, and refilled IAW the two step up to temp method as prescribed. All is good now, no squeak.
I decided to go with Amsoil's Signature Series ZF8HP700 fluid, since the OEM fluid didn't even last 40K miles. Hopefully it performs better. The shifts feel a little better already, but a little time will tell.
https://www.amsoil.com/lookup/auto-a...l-l/us-volume/
Carbuff2 (12-20-2019)
CThomas
11-30-2017 09:12 AM
PILLZ
11-05-2014 08:18 AM
