Broken plastic from suspension - need help ID'ing?
Hi guys, I found these clear/oxidized plastic pieces under my front right wheel hub the other day when pulling the car out of the garage. The car is a '16 R. The plastic is curved with adhesive on one side. I dug around and it looks like they're spring covers that go over the top coil by the spring isolator. The plastic is pretty flimsy and maybe just became brittle and broke off. I had the front isolators replaced last year. I can't imagine these serve any useful purpose, as brittle and thin as they are, but wanted to check with the group. Any thoughts?
Spring insulator, spring sleeve, they are there to dampen the sound when coil binds under load, you should be fine if you are not hearing anything.
Check for orange powdery stuff on your shock Mount from the engine bay, if your sleeves are falling apart, chance are the Mount bushing isn’t far from failing.
lpf4 (09-27-2023)
You are fine then, they are not structural. They are probably falling off due to age/use.
I don't even think they come into contact that often if you have stock springs, lowered however, they are a must, rear more so than the front.
These are what I got if you need replacement.
Johnken
02-17-2023 12:00 PM
Aarcuda
09-08-2019 07:49 PM
