Broken soft top - Trying to locate part
I'm having an issue with the flap/cover on the driver side no longer automatically opening/closing. The top is still fully functional if you manually raise and lower this cover yourself. Upon inspection it appears that one of the plastic ends on a little connector bar has sheered off(not shocking). In a perfect world I'd like to just locate one of these connectors but I'm afraid it will only come as part of some assembly.
In case anyone is wondering the warranty expired on it about a month ago so I'm really trying to tackle this myself before forking over a bunch of money to the dealer. I've included some pictures below to show what I'm talking about. Any help/thoughts/ideas are greatly appreciated, thanks!
Sheered off driver/left side. The bottom is cut off but there's only about another inch before it has the same connector end.
Normal passenger/right side. Here you can see the full length.
Looks like it is part & parcel of the vert roof lock assembly, part T2R1412, part #8 on this diagram: https://www.jaguarlandroverrenoparts...omponents-scat
But you would think it would be possible to get the end plastic piece separately, and I would try a wrecking yard first.
pbad (08-06-2017)
What is the diameter of the tie rod, and the ball that broken piece snaps onto? I have a bunch of carb linkage parts that look just like that. won't be plastic, but solid old fashioned cadmium plated steel.
I suspect you could find what you need at NAPA parts if I don't have what you need.
pbad (08-08-2017)
Thank you Unhinged for the offer, I appreciate it. My best measurement says it's about 6 mm. I was actually looking around in there and somehow the broken piece was laying on part of the top even after opening and closing a handful of times. I think I'm going to try fusing the pieces back together first and reinforcing it a little. I'd prefer something stronger than plastic as well but my guess is they went that way to make it malleable enough to just press on the *****. So I'll start with that and see how it goes for now before exploring other avenues. Appreciate all the replies.
You can paint that piece with primer and flat back to match.
