BSM not working
So a few weeks ago i bought an 2014 f type v8r with only 40k km';s.
After some driving i noticed the blind spot montoringsystem is not working.
Before i go to the dealer i want to understand the system.
Ofcourse i used the search, but little info is there.
My sitiuation:
When i start the car, in both mirrors the icons light up for a short time (Ofcourse in the cluster BSM is selected).
When i drive the car on the left side i have an orange dot and nothing happens when a car passes me.
On the right side nothing lights up, no dot and also nothing when i pass a car.
Also there is no error in the display.
If i'm correct:
When you start the car, there should be an orange dot in the left and right mirror.
When the car drives at higher speed, the dot's should go out and when a car passes the icon should lit.
In my case should i expect a problem on the right side, as there is no orange dot on that side?
Can you just swap the modules or is there some programming to do?
May be battery problem?
All info is welcome ...
My sitiuation:
If i'm correct:
CB1973 (04-22-2022)
Pcar2Jag
04-08-2020 10:27 AM
