bulkhead/firewall crack
Received 2,192 Likes
I LOOKED at a brand new f and they're there on all. That is actually overlapped panels and when doing things that require those to be removed like back spark plugs, injectors etc you have to remove the engine compartment and brake booster well liners which is what they are. it looked cracked but they're made that way. Look closer and you will see the over lapped panels with foam between them to make sure they're not a source of a squeak or rattle. but as with so many things until someone says something about it you never notice.
That could be Jags new catch phrase "Better than a clapped out 308 GTS"
Jaguar is a small car company competing at a relatively low price point for its size. You aren't going to get perfect components everywhere in the vehicle. They have less manpower, less budget, and less sales volume than everyone else in their segment. I'm honestly shocked they did this good of a job, and I think everyone should give them a break for making a shitty looking part hidden where you can see it. Clearly its doing its job just fine and if that's what Jaguar needs to do to make a vehicle like this profitable, so be it!
Why doesn't everyone bicker about the real problem... Jaguar's garbage customer service.
Having been hit with the bad clutch design and the flawed fuel filler neck, my experience with customer service has been stellar. Of course all of that is due to dealer, and I have to believe that the poor customer service received by others is mostly due to the poor practices of their dealerships. That said, I have to admit that JLR really bungled the handling of the Meridian issue and should have been more proactive in coming to a resolution.
#28
Stohlen did.
#30
I quite like seeing things like that when they don't detract from the finished product. It's like seeing pin marks on handmade furniture - it gives you an insight into how it was made and a brief connection to the person who spent hours rotating that part around in CAD checking each parameter was to spec!
#31
#35
#37
#38
That seam is a classic sign of CAD engineering. The liners were positioned and shaped by the surrounding components, clearances, etc, and then someone added an overlap seam to allow them to be removable and that little projection on the top face was either left to aid with the moulding process or simply ignored because the clearance gap was technically correct.
