Busy Week...
It's been a busy, and amazing (almost) week!
Tuesday - F-Type R Coupe delivered
Wednesday - ClearPlex window film installed
Thurs/Fri - Paint Protection Film installed on the entire front end, rockers, mirrors, and A pilars
Saturday... (see below)
Sunday - Clay/polish/Opti-Coat all panels not already covered by film
![](https://www.jaguarforums.com/forum/attachments/f-type-x152-72/101301d1416793319-busy-week-20141122_224132930_ios.jpg)
alexg (11-28-2014)
I actually purchased it pre-owned, with about 2,300 miles on it. So whatever break-in that should have occurred is complete by now. ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Had a great time at Sonoma. I've driven it several times before so just had to figure out how this vehicle behaves, and wants to behave. At such an unforgiving track (walls everywhere with very little if any runoff) coupled with rain in the morning, it was really a learning day and not one that was going to result in a new personal best time. 2:03 was all I did in the Coupe R.
Initial impressions about the car are:
- Turn in is excellent, as is overall steering feel
- Brakes are surprisingly good for such a heavy car (superformance, not even carbons)
- The traction control is a bit invasive in off-camber conditions (ended up turning it off)
- The chassis is nice and stiff, and quite balanced even with traction control off
- As one would expect, you have to modulate the throttle quite a bit to avoid over-driving the front tires or oversteer
- The tire pressure monitoring system is really annoying when you're running pressures below the street spec. It doesn't appear to allow you to recalibrate to the pressures of your own choosing, or even to the pressures defined in the manual for "closed course" operation.
Clay is harsh on the paint? Not really. It's essentially exfoliating the clear coat. As long as you apply something afterward (like wax or Opti-Coat in my case), the result is net positive. You extract contaminants while also improving the look/feel of the finish.
Seems that we need to figure out how to re-code a few options to fix nags like this.
alexg (11-28-2014)
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
