Buzzing behind driver’s side head
Old 06-01-2019, 04:10 PM
Blumtown's Avatar
Default Buzzing behind driver’s side head
Hey all brand new to the forum. I tried searching but no luck. More curiosity than anything, but at low speeds and light throttle, there is a mechanical “buzz” behind my head. Goes away once under way. Car runs fine but I figured the community may have encountered it. 2014 V8s. Thanks
Old 06-01-2019, 06:04 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
We’ve encountered that on the forum, but I can’t remember the resolution. Somebody is bound to fess up.
Blumtown (06-02-2019)
Old 06-01-2019, 09:43 PM
Blumtown's Avatar
Appreciate it. Guess I’ll just keep mashing the pedal and drown it out anyway 😂
Old 06-01-2019, 11:43 PM
RickyJay52's Avatar
Received 1,601 Likes on 861 Posts
Low speeds and light throttle? That sound you hear is the “devil” (in all of us) saying go faster. Much faster!
Old 06-02-2019, 12:57 AM
Blumtown's Avatar
Well then. I shall feed it.
Old 06-02-2019, 07:45 AM
Unhingd's Avatar
Old 06-02-2019, 10:03 AM
Blumtown's Avatar
Ah there you go. Thanks!
Old 06-02-2019, 12:46 PM
DJS's Avatar
DJS
DJS is offline
Received 2,106 Likes on 1,406 Posts
Yes, the vacuum pump tends to be busy around 1400rpm, as the valves are opening and closing.
Old 06-02-2019, 06:50 PM
Tp10XKR's Avatar
I heard the pump on my 15 R running on and off several times while idling in the driveway yesterday. I thought to my self “ that sounds odd” then searched it here.
1. Do I need to have this fixed as per the TSB. ?
2. Or is the pump defective, and just be replaced.
3. Is this repair covered whether or not under warranty?
Old 06-02-2019, 08:22 PM
Unhingd's Avatar
They’ll only fix it free if the car is still under warranty. They won’t replace the pump but will remove it and hook the muffler valves straight to engine vacuum.
Tp10XKR (06-02-2019)
Old 06-03-2019, 08:52 AM
DJS's Avatar
DJS
DJS is offline
The pump does cycle on and off, that's normal.
JimC64
09-05-2022 07:11 PM
multistrada74
08-24-2016 11:20 AM
ropetec007
03-04-2014 06:31 AM
Lcgi
05-13-2012 06:34 PM
xkrsupercharged
05-02-2012 12:39 PM
Quick Reply: Buzzing behind driver’s side head
