Caliper color change
Thinking of changing caliper from red to yellow, any thoughts, has anyone did it. My calipers are ceramic coated and so is the car this may cause an issue spraying, if I do go for the yellow is there different shades of yellow , whats the best or color name is there different types of yellow, also has anyone put on new JAGUAR decals that are the correct size back on after.
If going ahead I need a spray primer, yellow spray paint and clear coat, anyone know who does best paint and where to buy, and of course proper size Jaguar front caliper decals
The following 3 users liked this post by SinF:
Received 3,226 Likes
I used off the shelf Dupli-color "enamel with ceramic" yellow caliper paint. Perfect shade of yellow IMHO.
I don't know for sure if it will work over the top of ceramic coated calipers but I can't see why not.
No preparation needed other than a thorough clean of the calipers, I used simple meths and a MF cloth.
And I masked off the brake rotors either side of the calipers, then cleaned up the over spray with turps.
Any excess paint left behind on the swept surfaces of the rotors rubs/burns off completely with just a few brake applications
I had some trouble finding the correct "Jaguar" caliper decals (correct "modern" font and curved) but I eventually found them, I will chase up a link if you want.
Clear coat is not absolutely necessary, I have done without it on past Jags with repainted calipers and new decals and the decals didn't deteriorate one iota.
But if you really insist on clear coat over the top of the decals make sure it is the exact same brand and type as the colour coat, otherwise you risk the clear coat dissolving the colour coat and running all over your nice new decals. Don't ask how I know this!
Edit - I got the decals from The Sticky Scene, see here (then click on Jaguar): https://thestickyscene.com/stickers/brake-caliper/
BruceTheQuail (03-19-2020)
VHT should be perfectly OK, I have used it in the past with zero problems.
powerhouse (03-18-2020)
I like the red, dont mind the yellow but with the silver wheels I would consider black calipers. I actually think (but might be wrong) you will need to get rid of the ceramic coating first, the whole idea of ceramic coatings is to stop stuff from sticking to it. The paint is prone to chipping and flaking anyway.
powerhouse (03-19-2020)
Queen and Country (03-21-2020)
scm (03-19-2020)
Yeah, I was thinking the same. Problem is that I have custom orange and black wheels that came with the car currently installed as you can see in my signature pic. I also have the factory black 5 split spoke with the silver rim bolts and have been debating which to keep.
JacksonvilleJag (03-21-2020)
I really don't care for the red with these rims. I want to like the rims, but I think the red calipers are messing it up for me. I was leaning toward painting them black, but if I put the factory black rims back on, I think I'd want them silver. However, I too am the last one that should be color coordinating anything.
The following 2 users liked this post by Unhingd:
BruceTheQuail (03-21-2020),
JacksonvilleJag (03-23-2020)
jazzyjags
10-31-2018 08:41 AM
goblue90
09-30-2012 07:42 AM
