Camshaft error codes after long drive
After my drive from San Francisco to Los Angeles this weekend my car threw three codes related to the camshaft P0341, P0346, and P0366. Has anyone experienced these codes before?
Engine performance did feel less performant after the codes went off but maybe it's in my head. The codes went away and eventually returned. Going to take it to dealer but just wanted to see if anyone else encountered this? Going to flip to OEM tune tomorrow and see if still there. I would think they are unrelated.
My car battery has been having issues this week as well. It's not hosting a charge even after hours of driving. As soon as I turn off the car it complains about low battery. It's either the battery (which I suspect) or the alternator. I'm getting that replaced next week after my trip to Montreal. Maybe a low charge in the battery on startup is driving this issue as well? Sighhh
I think you mean chain tensioner, though I guess I wouldn't be surprised if these cars had tensiometers to throw codes.
Still have not been able to take the car in since I'm out of town until Wed, but before I left, I discovered a fail-safe way to trigger the codes. If I drive my car on an uphill incline and stop and leave it in drive, the exhaust system starts pulsating. The the exhaust system vibrates/pulses hard enough that it starts hitting the undercarriage of the car. It was super scary and it sounds like the car is planning to give up on life. As soon as limps off the incline (power gong in and out) onto a flat surface all seems well again. :scratch head :
No idea. I really need to take it to the dealer when I get back to SF, but they are always so backed up. No idea why I am getting these codes. Started after the long drive to LA, and now seems to physically manifest after I put back on the 200-cell. Not sure if they are related. My dealer over the phone said it could be related to my battery (will replace on Wed), it appears my battery is dying, won't recharge after driving, just enough to crank it, but as soon as i stop the car, the car gives a low battery warning.
The dealership tracked down the problem to low oil. I was a bit under a quart of the recommended level. On inclines (SF hills) it would start knocking and sputtering, power going in and out. After the oil top off everything seems to be smooth again, no check engine lights, no weird behavior on inclines. Would have thought the car would throw a low oil warning?? It is still weird to me that just 1 qt would result in this behavior. I hope it isn't something bigger issue that topping up the oil is covering.
Will continue to monitor closely. I am making the drive from SF to LA this weekend, we will see how well the car does.
As well, I would be really suspicious of the explanation around the cause and effect you experienced.. if the oil was that low it would be more than a quart and would cause damage, in my opinion.
I would make sure this is well documented.
Lawrence
Good thing they catch the low oil. Whatever happened to you happened to me as well before my engine died. Same codes, same problems, I had the Velocity Cats installed too.
I just wished that I was smart enough to look at the oil..
Didn't your oil level indicator show it low when you checked ? It certainly should have.
Lawrence
Lawrence
The car ran perfectly when on a flat road but displayed these "chugging" system when on an inline, so I intuitively assumed it was related to some liquid changing position versus a static mechanical problem.
This lack of pressure is caused by the oil pump picking up air which shouldn't happen if you were only
a quart below the recommended level even on a steep incline !
So there might be a calibration error of your electronic dipstick running the engine with less oil volume
as desired.
I would recommend to top up the oil level to full (as shown by the electronic dipstick). Next I would measure the oil
volume by draining the engine to be sure the correct amount of oil is in the engine.
Hopefully your engine isn't already harmed by running without sufficient oil pressure.
Regards
Ulrich
Camshaft error codes due to low oil level are obviously caused by a low oil pressure situation in the engine.
as desired.
Regards
Ulrich
as desired.
Regards
Ulrich
