Camshaft position error
Hi guys,
after having the amber engine warning light for about a week, i got myself a diagnostic tool: icarsoft lr 2.0.
After running a scan I found these errors:
P000A - Jaguar A Camshaft Position (CMP) Slow Response (Bank 1)
P000B - Jaguar B Camshaft Position (CMP) Slow Response (Bank 1)
P0011 - Intake Valve Timing Control Performance Bank 1 - “A” Camshaft Position – Timing Over - Advanced or System Performance
Reading on the internet the causes could be the
Low oil pressure due to restriction in an oil passage or a bad oil pump
A faulty camshaft position sensor
A faulty camshaft position actuator solenoid
and other things not at all nice to read...
Car is 2.0 My2019 with 26000KM.
Any advice? I'm really worried...
Thanks in advance for any suggestions and tests I can do on my own.
Mine is out of warranty from six months.
I don't think it is difficult to change this sensor and I could change it too. I should know where exactly the one in bank 1 is.
Is there a way to test if the cam sensor is in fault?
Possible that the problem concern camshaft position actuator solenoid?
if you find the invoice and if you remember the error code it would be a good thing ...
have you pdf of this recall?
The following 4 users liked this post by manuninja:
andre.iamma
05-21-2019 12:07 PM
