Can't Get Tire Pressure Reading
Seems like you can't get the tire pressure reading when the car is running. But when off, I'm able to go into the vehicle info menu to get the pressure of each tire. But suddenly, yesterday, the reading is all zero. any ideas? does the car need to be running for a bit? I swear I've been able to get it to show the pressure in the past. Don't see any other warning indicators saying anything is wrong with the monitoring system...
![Can't Get Tire Pressure Reading-2014-10-20-20.10.47.jpg](https://www.jaguarforums.com/forum/attachments/f-type-x152-72/98789d1480974058t-cant-get-tire-pressure-reading-2014-10-20-20.10.47.jpg)
Not sure about it being an option or new for 2015. But this is how I do it.
- engine is not running
- turn on electric power (start button w/o foot on brake)
- go into the vehicle info menu
- go to check tyre pressure menu
If it's an option wonder if it's just a software update since all cars have the TPMS AFAIK
HTH
HTH
jmfan (10-23-2014)
(new here) but most cars use the rotation of the wheels via the ABS/ESC system to calculate if they are under inflated. On my old BMW M3, it didn't detect my tire was basically flat until I was over a block away from my house even though it was down from the time I left. This is also why they can trip off even if the tire pressure is within a good value (i.e. the tires have worn down which also affects the rotation in combination with the pressure).
Thanks, that has to be it. No doubt, we have the same TPMS system in the 2014's but in our case it only alerts to a pressure problem, without a display showing tire pressures, which is fine. I had the option of reading tire pressures in other cars, but never used it. It's only accurate when the tires are cold anyway.
