Car alarm going off trying to charge dead battery
The car alarm will 'trigger' then chirp its built in speaker when the battery gets drained as it assumes someone has tried to disconnect power. Connecting a battery charger then powers the car's twin horns (which are extremely loud) as the alarm has been tiggered. The handbook says.... If the alarm has been triggered, it can be deactivated by any one of the following methods:
Pressing the unlock button on the Smart key. (only if enough amps to power the car's fob antennae)
Opening a door using Keyless entry. (only if enough amps to power the car's fob antennae)
Pressing the START/STOP button with a valid Smart key present. (may require the backup start procedure where you have to hold the key fob against the small depression in the lower driver facia. Page 78 of user manual)
Basically if you can get the car started the alarm will reset and your neighbours will be happy )
Carbuff2 (10-18-2024)
Maddan
08-01-2015 09:31 PM
