Car alarm going off trying to charge dead battery
Old 10-17-2024 | 04:29 PM
littletones's Avatar
I don't. The battery charger I have does have a 200A engine start function though.
Old 10-17-2024 | 06:46 PM
genp729's Avatar
The car alarm will 'trigger' then chirp its built in speaker when the battery gets drained as it assumes someone has tried to disconnect power. Connecting a battery charger then powers the car's twin horns (which are extremely loud) as the alarm has been tiggered. The handbook says.... If the alarm has been triggered, it can be deactivated by any one of the following methods:
Pressing the unlock button on the Smart key. (only if enough amps to power the car's fob antennae)
Opening a door using Keyless entry. (only if enough amps to power the car's fob antennae)
Pressing the START/STOP button with a valid Smart key present. (may require the backup start procedure where you have to hold the key fob against the small depression in the lower driver facia. Page 78 of user manual)
Basically if you can get the car started the alarm will reset and your neighbours will be happy )
Carbuff2 (10-18-2024)
Old 10-17-2024 | 09:22 PM
Let the alarm blare away for about 5 mins before the smart key let me unlock the car to finally get it to shut up. Took a little bit longer to get the trunk released.
Gave my neighbors a heads up so no headaches on that front yet.
scm (10-18-2024)
Cat2
07-13-2016 09:15 AM
Maddan
08-01-2015 09:31 PM
richard134
05-02-2014 01:48 PM
aprilneo
02-08-2013 07:48 AM
jerzejag
12-01-2011 03:03 PM
Quick Reply: Car alarm going off trying to charge dead battery
