Car jerks when put in drive every morning
Old 12-01-2015, 08:28 AM
bjg625's Avatar
Almost all cars start in 2nd in normal mode today for gas stats. I have same ZF in our Maserati and it is programmed completely different. I prefer Jags. BMW uses this trans and it is different again as is Land Rover. I see nothing wrong with the trans but it is better in sport or full dynamic. In the Maser it is completely different in sport, much more fun! But if you start in first all the time the gas mileage does change significantly.
  #42
Old 12-01-2015, 05:32 PM
BierNut's Avatar
I too experience the "jerk" when putting the car into D after a cold start. The car developed this over time, as it did not do it new.
On my car, it is not related to the higher start-up RPM. My normal starting procedure is to not only wait for the RPM to drop to idle, but also for the temp gauge to move off the (digital) peg, usually 60-90 seconds depending on ambient temp.
I have to put the car in reverse first, but only get the "jerking" when put into drive. All other shifts after this are smooth, and I've not had any other issues with the transmission or shift quality.
  #43
Old 12-01-2015, 08:35 PM
Nati's Avatar
Originally Posted by Foosh
I feel it first thing in the morning when the engine is cold and in a higher rev mode, but my description of the symptom that bothers a few folks is a firm shift into D at higher revs. If you wait several minutes until the engine is near normal temp and drops down to the normal warm idle rev, it doesn't happen, but that's completely unnecessary. I can reproduce the same thing on any automatic transmission by increasing the revs slightly in neutral before shifting.
In the video posted he waits for the car to idle down.
  #44
Old 12-01-2015, 10:11 PM
Foosh's Avatar
Received 1,028 Likes on 854 Posts
There are 3 idle stages: 1) high-rev start-up; 2) which idles down to a lower cold idle after approximately 10 seconds, and 3) an even lower warm idle when car is at normal operating temp.
My car does exactly the same thing as seen in the video, and has since new. I remember this distinctly because after having the car for a day or two, I put it into gear during the initial high-rev start-up, and it died. That's the only reason I would remember it was doing the same thing brand new, because I paid very close attention immediately after that, fearing something might be wrong. I haven't repeated that error since.
Absent an experience like that to closely focus my attention on that particular characteristic, I wouldn't have accurately remembered what it did 18 months ago new, because there are so many novel things to take in on a totally new vehicle. Any new experience is akin to sensory overload. It's also a normal characteristic of human perception to notice more and more details and pick up more subtle nuances as a situation becomes more and more routine. Thus, it would be normal to think something wasn't happening when new that is happening now because attention was diverted elsewhere and all over the place in the beginning.
I'm not trying to be pedantic, but I earned my PhD in experimental psychology (e.g. human perception). What I'm trying to describe is a normal, well-documented, human phenomenon.
BTW, The squeak is the cold brake pads against the cold disks when the car goes into gear. Mine makes that same exact sound from the video when starting out in the morning. Every day, it repeats the same start-up behavior about 10 hours later, when I leave the office.
Uk2usa (12-22-2015)
  #45
Old 12-03-2015, 01:56 PM
speedhacks's Avatar
Originally Posted by jallitt
here's a video from this morning.
f type startup - YouTube
after the revs die down (30 seconds in) I select D - 1.5 second delay and the car lurches forward with a squeak. Then I select neutral and D again and no jerk - just a feeling of it pulling.
FWIW ambient temp in the garage was over 60F (it's spring here) so I don't think freezing temperatures are a factor.
It looks like you're parking with load on the transmission.
Was this on a hill or anything? Also, when you park, are you applying the parking brake THEN selecting park.
My car doesn't exhibit any of these noises, movements or clunks. Mine is an R (not sure if that makes any difference).
Temperature does not matter. Smooth as butter selecting any gear from start up and driving. I always come to a stop, apply the parking brake, then select park on the transmission. This way the cars weight is not resting on the transmission.
  #46
Old 12-03-2015, 03:02 PM
CaptainHam's Avatar
It's none of these. I park my own car in a level garage, after first letting it settle in neutral (not that any settling is required) and don't apply the parking brake at all.
Mine is also a V6 for what it's worth.
  #47
Old 12-03-2015, 03:18 PM
Foosh's Avatar
Actually, the parking brake unloads the transmission completely if you apply that before putting it in Park. The car won't let you shut down in neutral as it will automatically go into Park.
There's almost no such thing as a completely level floor. You can put a bubble level with an electronic readout down on almost any "level" floor and find it off by a few tenths of a degree. Once in Park, it will often drift a bit loading the transmission ever so lightly unless the parking brake is engaged.
At any rate, I also park on a level floor and use the parking brake in the above manner everywhere I park, and my car still exhibits the same symptoms in the video every time I start it cold. I consider it normal.
  #48
Old 12-03-2015, 03:40 PM
jallitt's Avatar
My garage is dead flat and behaviour is the same whether park brake is applied or not.
The main concern is the 1.5 second delay then the slam into 1st.
If it was solely rev-related - why is the second N->D always smooth?
And leaving the car idling for 5 minutes so the revs really have finished dying down to "normal" idle speed and the the temp gauge is sitting in the middle (at 65 F ambient temp) it still jolts the first time you hit 'D'
Also my MY15 V6-S is always in 1st after selecting 'D' (but I can manually select 2nd with the paddles). If you coast to a stop in manual it will stop in 2nd and you have to manually change down if you want 1st.
  #49
Old 12-03-2015, 05:50 PM
Foosh's Avatar
Take it in for repairs. It's clearly bothering you.
  #50
Old 12-22-2015, 10:41 AM
WhiteTardis's Avatar
Any resolution to this? My car has been doing this recently just as severely in your video.
  #51
Old 12-22-2015, 11:56 AM
Uk2usa's Avatar
You may want to take yourCar into the Dealer, the Transmission might Ned to be " quick-learned". This is done with a scan tool. It basically makes the trans apply all the clutches and the controller sees how long it takes for each clutch to apply. Then the controller can adjust the timing of the clutch applications for smoother shifting.
Or maybe just a software update/re-flash might be needed? Or check the Trans fluid level?
By the way, the ZF-8 is an awesome transmission, I have one in my SUV. It's capable of handling over 700 ft/lb of torque. Even Rolls Royce use them.
  #52
Old 12-22-2015, 11:57 AM
Uk2usa's Avatar
Ned?? NEED!! Sheesh.
  #53
Old 12-22-2015, 01:17 PM
RickyJay52's Avatar
Received 1,601 Likes on 861 Posts
Forgive me but you do know you can EDIT your post to correct...well...anything?
Uk2usa (12-22-2015)
  #54
Old 04-06-2016, 02:56 PM
Overblown's Avatar
My LR4 does the exact same thing. Same transmission. No. it's not normal. I'm not saying its a problem but it's not "just what transmissions do." I've just come to accept it which is easier as it doesn't happen often.
  #55
Old 04-06-2016, 03:46 PM
CaptainHam's Avatar
Since I lasted posted on this some time ago, I've been making a real effort to really let the car settle in the garage before putting it into Park...waiting at least 5-10 seconds once it's definitely stopped moving. Seems to have worked as I haven't experienced it since (and I previously experienced it nearly every time before).
Maybe next time I won't wait and will put it straight it into Park, just to see if it reoccurs (who knows, maybe something else was causing it and now it's fixed itself, so worth checking out).
  #56
Old 04-06-2016, 07:53 PM
Overblown's Avatar
Mine started doing it after a few thousand miles too. Didn't do it when new. This is my second LR4. My XF doesn't do it ,neither did my last LR4, both of which have the same transmission. All evidence points toward it being a ZF8 "thing".
  #57
Old 04-06-2016, 07:57 PM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Let the clutch pedal out more gently!
  #58
Old 04-06-2016, 07:59 PM
Overblown's Avatar
Don't I wish!!
  #59
Old 04-06-2016, 08:03 PM
Unhingd's Avatar
Don't I wish!!
more seriously, how fast is your engine idling in Park before you shift into gear? And then how fast is it idling in gear with foot on the brake?
  #60
Old 04-06-2016, 08:35 PM
Overblown's Avatar
I just deal with it these days. It's been a long time sense I really messed with paying attention to all of that so I don't recall. What I do know is that nothing I did helped. It's one of those problems that just big enough to notice, but not big enough to fuss over for long.
Quick Reply: Car jerks when put in drive every morning
