car not starting
car not starting
Hey guys, so i have a 2015 jaguar f type R. As i was driving one day it was driving normal then a few seconds later it started running really rough and a knocking sound coming from the top of the engine so i parked the car at a friends house after 3 mins of driving and now the car won’t start, it would turn but not crank so the car has oil, battery is fully charged, new alternator and starter. when i scanned the car i got these codes; P0A0F(engine failed to start) and P0011( camshaft position timing over advanced) btw i’m a mechanic and i honestly ran out on ideas on why it won’t start. i’d appreciate you guys ideas!
Based on your code(s). Possible or probable causes are:
The comprehensive component monitor (CCM) monitors the VCT position for over-retarded camshaft timing. The test fails (and you get the error) when the camshaft timing exceeds a maximum calibrated value or remains in an retarded position.
So you have an issue with the VCT on Bank 1. One other thing to check is for clean (and enough) oil. On my 997 TT I can occasionally get a VCT code if/when oil is dirty and may prevent the solenoid from working correctly, or a spec of dirt.
Good luck.
DC
- Cam timing improperly set Continuous oil flow to the VCT piston chamber
- VCT solenoid valve stuck open
- Camshaft advance mechanism binding (VCT unit)
Good luck.
DC
Good luck.
DC
Good luck.
DC
Can't help you there. However, I have this OBD guide from 2014 for the AJ133 (V8). It doesn't have much on P0011, but it does have a lot of the starting logic and flowcharts, etc. May or may not be helpful.
https://www.dropbox.com/s/1ek33ux7tf...guide.pdf?dl=0
Good luck.
DC
Good luck.
DC
i had forgot to mention that i did install a mina gallery complete upper and lower intake system. i doubt it’s possible that would cause the problem but the car did idle slightly rough nothing crazy i was talking to velocity ap and mina to see if a tune would be required
Here is the best I have to help on the VCT. The PDF has all of the Engine Electronic controls.
DC
Badpenguin
09-25-2021 10:52 AM
