Car rolled away when in park
I have a F Type V8 S. The car was parked in the garage, and rolled away to the end of my drive. Nobody was around the car, and the key fob was in the house when this happened. The car has been at the dealer for a few weeks now with no resolution. Has anyone else experienced anything like this?
Was the e-brake on? I suspect preemptive failure of the little pin in the transmission that is called "Park". I don't find it advisable to ever park a car without using the parking brake. It's a tiny pin in the transmission that holds the sprockets and gears in place preventing the car from moving. It's not strong enough to hold a car's weight in place indefinitely.
The car goes into park as soon as the electronic ignition is shut off. According to jaguar, all your suppose to do is power off. I've done that for the first two month I owned the car with no problem. Then one day it simply rolled away.
Received 6,307 Likes
You are actually not supposed to Switch Off the ignition while the car is in drive. It never engaged park position, that's why that happened.
It's more of convenient feature, if you forget to switch it to park before turning off the ignition, it will go into park automatically.
Directly from the handbook:
SWITCHING OFF THE ENGINE
With the gear selector in position P, press the engine START/STOP button.
Before exiting the vehicle, always ensure that the gear selector is in the Park (P) position, the engine is turned off, the parking brake is applied and the Smart Key is removed from the vehicle.Park (P) should be engaged and the parking brake applied when the vehicle is stationary. The vehicle can move unexpectedly with any other gear position selected, which could result in death or serious injury.
The neat thing about how Jaaaag is doing parking brakes is that you can power off the car and pull up on the little ebrake switch. When turning it back on, as soon as you put the car into a gear, it takes the ebrake off for you. Not that this explains your mysteriously walking cat, but it may provide additional piece of mind. I'm one of those weirdos that actually use the ebrake. On all of my cars be it manual or automatic.
[QUOTE=Executive;825204]You are actually not supposed to Switch Off the ignition while the car is in drive. It never engaged park position, that's why that happened.
Before exiting the vehicle, always ensure that the gear selector is in the Park (P) position, the engine is turned off, the parking brake is applied and the Smart Key is removed from the vehicle.[FONT=sans-serif][FONT=sans-serif]Park (P) should be engaged and the parking brake applied when the vehicle is stationary. The vehicle can move unexpectedly with any other gear position selected, which could result death
Thanks, I totally understand however the dealer explained that it is not necessary to apply the e brake. I have always used a parking brake when driving a typical manual car. Jaguar cars are suppose to engage into park while just simply stopping and turning the power off. As I said I fix this, and found my car at the end of the drive. I will be using the e brake in the future . Thanks again for your advise.
[QUOTE=Davidfarber100;826135]
The problem is I have always pug the car in park before turning the power off. I do admit I may not have followed that sequence that time . I would hate to think I power off first, then the car does it again. That's why the system was designed the way it was. I think the e brake is gonna be a must . Thanks
I maybe wrong, but I think I read that if you turn the car off in any other gear other than park, the car will shift into park AFTER 10 minutes. This is done so you can move the car if it needs to be towed or moved by hand. NOTE: It will shift into N when you **** it off not Park
Are you sure that you didn't bump the gear selector into neutral by accident and then shut the car off? It wouldn't be hard to do.
"Note: If the engine is switched off with
Neutral (N) selected, the system will wait
for 10 minutes before selecting P. This
procedure is to allow the vehicle to be
conveyed through a car wash only and
should not be used for vehicle recovery
purposes. See 182, TRANSPORTING THE
VEHICLE."
There's a million "How to" videos on the jaguarUSA website under the "owners" heading. I have watched nearly all of them and I seem to recall one of them saying that the car automatically goes into Park if the ignition is turned off (when the car is not moving). Nevertheless, using the parking brake is worth the effort since the automatic disengage feature makes it very user friendly, and it will keep the cat in its cage and out of your neighbor's front yard.
Fascinating subject...........but here's the 64 million $ question: what holds the e brake
on after you leave? on my XK I can feel it come on thru the brake pedal; it goes down just a tad, must be a hydraulic lock but does it increase the battery drain? If so that's all we need!
My garage floor is level so I don't need to use the e brake...............
Just wondering, (being a retired engineer I like to wonder a lot! my wife hates it!)
Cheers, Adrian
Cheers, Adrian
BrentGardner
28
04-26-2024 03:08 AM
FS[NorthEast]: 1991 xjs v12
DrScientist
12-09-2015 07:36 PM
stanjag
08-30-2015 10:35 AM
Will P
08-27-2015 06:52 PM
