Carbon Ceramic Matrix Question
I currently drive a 2016 XFS and about to pull the trigger on a 2015 used F-TYPE R as a weekend toy. One of several I'm looking at has the Carbon Ceramic Matrix braking system. I've heard reports that these squeak during stop & go traffic which is contrary to my belief that ceramic pads are dustless & quiet. Can any of you with this option comment on the noise or the lack of noise with this set up?
Yes they are noisy. Ceramic pads produce less dust and are quiet on steel rotors, yes; however the ceramic brakes on the F-type is in reference to the rotors and not the pads. Carbon ceramic brake rotors are noisy and honestly not very good on the street. They are for racing/track purposes mainly and don't perform as well as a steel rotor system for every day driving.
If you're not planning to track the car regularly and don't care about how your brake rotors look, there really is no reason to get a car with the carbon ceramic kit. It's a very expensive "upgrade".
No noises at all with ceramics on the jag
Nothing but positives here, especially in terms of maintenance given zero brake dust
The only noisy ceramics I've had was on first gen cars like my turbo s 996 a decade ago, and even then the noise was random with the bigger issue being pedal modulation/bite
They have now engineered all those early issues out
I have the CCBs on my R. Yes, they will squeak from time to time, more so when they are cold. They do work marvelously, there is no break dust, and they are supposed to last longer than typical brake sets.
With that being said.....I curiously asked my dealership to price out replacements for when that day comes. For pads and rotors, the cost came to $5k PER WHEEL!!! The key to having these is to replace the pads before they reach past a 50% life left. Past that point, there is too much heat transfer, and you will need to replace the rotors too. The pads by themselves should cost $4-5k for the entire car. The other option is to get rid of the car before replacement time rolls around....
That all being said, I would not bother with them next time around. The original cost of $12k and the potential replacement costs don't provide enough value in less brake dust and longevity.
Received 3,226 Likes
I just checked on Rockauto, and they show pads for the CC brakes at just under $229US for all four corners. Albeit Centric PosiQuiet metallic which by my experience are not the best pads around, but who knows how they compare with other options for the CC brakes.
See here: 2016 JAGUAR F-TYPE 5.0L V8 Supercharged Brake Pad | RockAuto
the rears are very smooth, the fronts are textured, not sure if this is normal?
im getting noise from the front like a low pitched vibration like the pad is rubbing on a textured disc and I can feel it through the pedal.
