Carbon Fiber Panels Feeler
#41
Progress made. Scanned the entire car and all bits and pieces I'm looking towards designing (Splitter diffuser, side skirt ) Along with the engine panels. I should have models complete and tooling ready to be the end of next week. We are out of NASCAR build season, so I should be able to have these molds machined rather quickly.
In case anyone is curious, the dots are a reflective positioning for the laser/ white light reference. Used around 1500 I believe (And yes they are stickers , so I was buffing residue off for hours).
I'm using a Creaform 700 and a GoScan50 to scan the car and parts.
The 700 gives a resolution of 0.050mm and up to 0.030mm accuracy. 7 Laser crosses aid in a good quality scan for a perfect fit of the parts I'll be designing.
Some photos of the process below. I'm thinking about making a quick mold for the rear wheel molding flare as well, in carbon. I'll work on the aesthetics and see if I can design something a little more aggressive. Look forward to some awesome sketches soon as you guys can help select which designs I move forward with.
I'll keep you guys updated with the mold process.
Regards,
Derek Fricke
Regards,
Derek Fricke
Foosh (07-24-2015)
#42
Looks like an interesting process. I can see how the laser scanning/mapping system captures the external dimensions of a piece, but how do you capture the mounting points/screw holes/tabs that are used to affix the pieces to the car without disassembling the pieces and scanning them individually?
Very cool. I had those pieces wrapped in CF on mine as well, and it does look much nicer, though given their size it isn't noticeable unless you're looking specifically at those parts.
You might also want to scan the interior console pieces to create molds for those too. They just pop out as 3 pieces and should be easily scannable.
Nice! I look forward to your progress and sketches/models/designs.
FrickenJag (07-24-2015)
#43
Only way to capture the mounts, screws , tabs is to remove the parts and scan both sides to generate a full surface model.
For instance, I scanned the center rear bumper diffuser on the car to make sure I had an accurate mounted position with no flex, then removed and scanned the backside mount tabs and bolt hole locations. Its certainly not a short process to do everything. Did the same with the engine bay covers as the factory plastic flexes a little when installed.
You're attention to detail seems to be similar to my own. I was thinking a similar shape, just more robust and follow the arch around a little more.
Pertaining to console parts, yes yes and more yes. This is something I've been debating. Is it better to carbon wrap, or make a mold. The downside with mold is I need to locate an additive tab for the factory mount locations, fixture for location tabs properly etc. Or with wrapping the factory trim in carbon you can use a 0.25mm weave that shouldn't throw off edges. If the was enough interest in carbon interior items, I would move forward with mold / tooling cost.
Regards,
Derek Fricke
Regards,
Derek Fricke
#44
FrickenJag (08-18-2015)
#45
Update. I'm wrapping up the mold files for the carbon covers and all is looking good. I just need to setup the programming for the mill and we will have things rolling.
Below is an image of the mold file for the passenger side cover. I'm sticking to a factory (non-aftermarket) appearance. Just a nice enhancement to the engine bay.
Regards,
Derek Fricke
Regards,
Derek Fricke
The following 4 users liked this post by FrickenJag:
#47
Update. I finally have a few guys lined up with quotes for machining molds.
I'm going to see how many people are truly interested in these, then pull the trigger on the molds as they are certainly not cheap.
I'm trying to keep pricing as fair as possible as I would like to see these on many cars and not just my own toys. No added labels to parts. Clean factory replacement look.
Rough ball park estimate for the panels are as follows:
Left and Right covers will be around 500$ /piece.
Front Large Radiator cover will be around 700$.
Total Kit will retail :~1700$
Package sale for all panels 1400$ for early bird discounts.
I'm going to match the twill that is on the exterior Jaguar parts. These are direct full carbon replacements. USA manufactured. No covers, or overlays etc. Colored carbon fiber may be options soon as well.
I will have induction tubing setups for both 4.2L and 5.0L setups to match soon.
If any one is seriously interested perhaps we can start a poll. I should have some finished parts in a few weeks depending on when I bite the bullet for machining tools.
Best Regards,
Derek Fricke
Best Regards,
Derek Fricke
FrickenJag (09-14-2015)
#49
That's on my too-do list as well. One of the parts next in line. I will be able to reproduce the factor R-S cover or slightly tweak it to look even better.
Assuming there is some interest in that along with these parts I'll design the mold and surely be much cheaper than the factory price, with equal quality and fitment.
#50
FrickenJag (09-15-2015)
#51
Yes, I considered that as well when first diving in. Biggriff has produced a carbon cover that fits the 5.0L setups. So I held back on that for now. For the 4.2L setups, I much rather have the Engine cover removed as the engine has a nice appearance. The other thought was I'm not too sure why the engine cover is there anyhow. On the XKR-S model and the XKR-S-GT, the cover is removed. More than likely for better air flow. Hence, I was led to offer something that wasn't already out there. I plan on making a nicely designed cover with louvers in the near future.
See Biggriff's carbon cover below:
https://www.jaguarforums.com/forum/x...-cover-145441/
Thanks for the input,
Derek Fricke
Derek Fricke
#52
FrickenJag (09-16-2015)
#54
#55
I was thinking that the 5.0L cover fit the V6 as well, is this not the case? I figured jaguar would have made the two the same to encourage purchasing of their carbon unit.
Has anyone checked the fitment? If this is something you guys desire to purchase I'll certainly design one that fits. I just need to scan the engine bay of a V6 and V6s. If the factory 5.0L fits with some slight trimming that would speed things up.
When I do start on the cover, what I will do is put together a few iterations of the design and you guys can help me tailor the design to what you like. This way its a group effort and everyone can contribute in the aesthetic parts.
Additionally,
Anyone that purchases the 3-Panel replacements, will receive a 25+% discount on the final carbon engine cover once I reverse engineer it. If I can line up a few people that are interested, I will justify investing in the scanning/reverse engineering/and tooling the engine cover while I'm doing the intake tubing.
Regards,
Derek Fricke
Additionally,
Regards,
Derek Fricke
#56
Regards,
Derek Fricke
Regards,
Derek Fricke
I would like to see a price quote.
#57
#58
Best Regards,
Derek Fricke
Best Regards,
Derek Fricke
I would be interested in the whole kit, including the engine cover.
Will all fit the 2016 R?
FrickenJag (09-18-2015)
#59
#60
