Carbon Fiber Steering Wheel Trim - TMC Motorsport
Old 04-24-2019, 08:42 AM
STMPY's Avatar
Default Carbon Fiber Steering Wheel Trim - TMC Motorsport
Hi - I just took delivery of my F-Type and am the unfortunate victim of the sticky interior. The Steering wheel trim got the worst of it. During the cleaning process the previous owner, or dealer wrecked the plastic trim finish below the sticky bits. The upper and lower trim, to be precise, Parts 2 and 3 below (NOTE: Part 2 is not available for purchase through Jag)
Now to the root of the question - has anyone used https://www.tmcmotorsport.com/ to buy these, unless the forum has had bad experiences:
Old 04-24-2019, 11:20 AM
JgaXkr's Avatar
I have one on order. It is due in a few days. I will report back once it arrives.
STMPY (04-24-2019)
Old 04-24-2019, 11:22 AM
STMPY's Avatar
Thanks you! I'll wait until you receive yours. I appreciate it!
Old 04-24-2019, 12:20 PM
WJV's Avatar
WJV
WJV is offline
How do you remove the bottom trim piece on the wheel (at the 6 o'clock position) without removing the airbag cover?
Old 04-24-2019, 12:59 PM
STMPY's Avatar
Just a gentle pry from the back straight out. Here's a pic so you can see the backside clips:
WJV (04-25-2019)
Old 04-24-2019, 01:00 PM
STMPY's Avatar
Has anyone removed the upper trim piece? I'm about to do that one, but it's making me nervous.
Old 04-25-2019, 08:14 AM
WJV's Avatar
WJV
WJV is offline
Thank you! What is the part number for this piece? Can't seem to find it on jaguarparts.com
Also, do you know if the gloss black trim ring on the steering wheel is replaceable? Mine has a small ding in it that's bothering me now that I've basically replaced everything else in the cabin. Where can I find the part number for that one? Dealer is under the impression the airbag cover, trim ring and airbag are all sold as one unit.
Old 04-25-2019, 10:18 AM
STMPY's Avatar
Jaguar Reno has the part:
https://parts.jaguarreno.com/v-2014-...wheel-and-trim
TMCmotorsports.com sells a carbon fiber kit.
I've seen aftermarket horn cover rings, but nothing through a jag dealership. Not sure where - maybe aliexpress.com ?
WJV (04-25-2019)
Old 05-27-2019, 03:07 PM
Lizard's Avatar
I'm also curious to know if any one had done this?
Can it just be pried out like the bottom piece, or does one need to remove the airbag cover?
Old 05-27-2019, 06:59 PM
frostysauce's Avatar
Yep! Did this a few weeks ago. It wasn't too difficult but it did take me a while to figure out the proper leverage for the clips holding it in.
I was able just to use a smallish flathead screwdriver. There are clips on either side, rotate the wheel either way 90 degrees and slide your tool of choice into a slot you will be able to feel on the back. Basically, the clips are 'pinch' style, so you will be pushing the clip towards the center of the steering wheel until it unclips. Do this for either side and the airbag comes right off with no hassle.
Make sure you disconnect the battery and wait 5 minutes. Also, be careful with the wiring harness in the steering wheel, not sure about yours but mine was a little brittle when pulling off the trim piece.
The following 2 users liked this post by frostysauce:
Carbuff2 (05-28-2019), STMPY (07-24-2019)
Old 05-27-2019, 08:22 PM
JgaXkr's Avatar
Did you have to remove the airbag to install the steering wheel trim?
Old 06-30-2019, 12:37 PM
Tommy Harshaw's Avatar
I'm also interested in this mod. Does anyone have a video on the install? Don't want to break the little clips
Old 08-13-2019, 09:48 PM
Peter O.'s Avatar
Also would like an install video so I don't brake the little clips
Old 08-14-2019, 05:14 AM
xrix4096's Avatar
Is that TMC kit for the normal wheel or the flat bottomed one?
Old 08-15-2019, 07:55 AM
Q2u's Avatar
Q2u
Q2u is offline
Default Steering wheel upper trim
Did anyone ever get the upper trim removed? Do you just pull, or does the airbag have to be removed?
Old 08-15-2019, 09:26 AM
Airbag has to be removed to remove the upper trim
Old 08-15-2019, 09:27 AM
TMC is just a reseller for Koshi Group who makes these products, you can go to Koshis website to look at their entire lineup. As far as I can tell the carbon pieces that go over the leather only fit the flat bottom wheel.
Old 08-15-2019, 05:03 PM
edfuhs's Avatar
I purchased from TMC and all CF parts clip on to the existing surfaces. I did not have to remove original parts. All fit rather well. Fulfillment is very slow so you have to be patient.
The following 3 users liked this post by edfuhs:
Burt Gummer (08-16-2019), Itismejoshy (08-20-2019), Jaguar1611 (04-01-2021)
Old 08-16-2019, 01:09 PM
Burt Gummer's Avatar
That looks very nice! If the parts don't 'feel cheap' and wobble around. Visually super cool.
Old 08-16-2019, 08:12 PM
Mpowerr's Avatar
From the original pictures it looks like its a very thin piece with adhesive that go over the existing pieces. Is that not the case?
Quick Reply: Carbon Fiber Steering Wheel Trim - TMC Motorsport
