Hi everyone, I’ve had my F-Type R for about a month now but the previous owner had removed the strings holding the cargo cover (presumably because one broke) but now I want to get it fixed because i’m tired of holding up the cover with my head as I remove things from my trunk. I also don’t want to remove it completely. I know that the strings are part of the entire assembly so I’m not trying to spend $600 to replace the entire cargo cover (nor $300 for a used one). Has anyone had any good ideas on how to replace the cords and what they used? I don’t know what kind of grommet fits in the cargo cover hole or what that would be even called and what type of string would work best. Another idea I had was to buy the range rover one (since the string and loop looks similar) and cutting off the big plastic anchor bit, but I still don’t know how I would secure the string to the cover itself. Thanks
Someone else started a thread about this very thing some time ago. You may want to attempt a search for that thread to see if they reached a satisfactory conclusion.
As for my two cents, it looks like it would be a very simple MacGyver fix. Using a large upholstery needle thread a braided nylon cord down through the same spot of the originals (thru the small rubber or plastic washer-like objects if still present--otherwise obtain something suitable); secure the under side of the cord to the cover using a suitable washer-like object (maybe even a black button) and form the loop that affixes to the upper attachment points. Done! Total cost a couple bucks and a half-hour of your time.
This is where i’m stuck because I don’t know what to look for or what this could be categorized as at the hardware store lol. But the rest, especially the nylon suggestion, is great thanks
I didn’t know there actually was a part number for the cord itself, everywhere else on the forum (and jag part websites) list it as only the entire assembly. This was very helpful, thank you
Beveled faucet washers would probably suffice. Home Depot or Lowes or Ace Hardware.
I couldn't see any practical way to fit a replacement cord to mine when it pulled out. Fortunately, the whole thing was replaced under warranty because the reason the cord pulled out was that the cover had jammed against the rear hatch after falling off the hinge pegs, and broke when I forced the hatch open.
I think I understand. When my family and I crossed the prairies by covered wagon...oh, never mind someone will just be offended/triggered/insulted or otherwise unappreciative of my warped sense of humor.
Parts:
-5mm nylon push rivet (one with a screw) from Lowes here
-nylon 350 parachute cord/paracord
Well after almost a year I finally figured out a good fix for this. After looking all over the internet and there being no exact solutions/parts at all this will likely be the first concrete solution. Below are the pretty simple steps:
1) Ensure there is nothing attached (string, grommets etc) to the cargo cover and that only the 2 holes are there (flush with the surface)
2) Tie paracord to each of the circles on the hatch
3) Cut string equally on both sides
4) Insert grommets without screwing in
5) Tie off one end around the screw and then screw it down
6) Lift cargo cover to make sure there is only “half” tension and repeat the previous step for the other side (and make sure length and tension is even on both sides)
7) Cut off excess string
Thats it, you no longer have to hold up the cargo cover with your head or look to buy an entire new cargo cover for $600
Thanks, great to hear that there is an easy fix. The power hatch snapped one of mine when the cargo cover slipped off the pegs (as mentioned above) and got stuck. It currently awkwardly hangs from one string, and sits on one peg. Honestly, the root cause here is the pegs not being long enough. I even took out the trunk trim and tried to adjust them when I was in there as part of a separate project, no dice.
I just removed the cargo cover, wrapped it in a large trash bag and stored it in my garage. It is easy enough to install should I feel the need to cover any contents in the luggage compartment, like if I am going on a road trip for a few days. It makes the interior feel a bit more open as well.
I just had my MY2018 cargo cover replaced the other day [under warranty] and noticed JLR changed both the cargo cover fabric and how the cords are attached. They went to a smoother fabric that is not quite as black [almost looks like a really dark gray] and the cords are fed all the way through the cover and affixed on the other side. I guess JLR got tired of replacing these. This design is very similar to a Saab 900 I had back in the day. Even if a cord breaks, it should be an easy fix now.
My parcel cord broke because the shelf falls off of the pegs. I ordered a new cord but I was worried it would fall off and break again. To solve this issue, I installed rubber washers that I found on Amazon. It prevents the parcel shelf from sliding off of the posts. Even with one cable the shelf is stable and don't fall off of the posts.
This poster must have been clairvoyant (or genius) inasmuch as the strings that suspend the cargo cover in my 2022 model use this method as opposed to the method in my older 2018 model.
What's this part/Cargo Cover shelf string. Washers work!
Got these washers in from post 14. Have 8 leftover in bag. Please PM me with US mainland address and I'll send you two, I will cover mailing costs.. no biggie.
