The case of the disappearing coolant
Old 01-08-2021, 03:39 PM
sov211's Avatar
Received 2,245 Likes on 1,361 Posts
Originally Posted by OnlySlightlyEvil
well, it's worse now. I drove away, gave it a spirited run; then my water pump shot water all over the front of the engine.
car never overheated; it's back at the shop.
I think I'm selling after this.
this is an irritating but minor issue. Have the waterpump replaced and continue driving this beauty.
Old 01-08-2021, 03:56 PM
OnlySlightlyEvil's Avatar
Not just the water pump, a bunch of hoses. I'm out $2700+
Old 01-09-2021, 07:05 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
That’s only 3 or 4 months worth of car payments with no significant depreciation over that period. Compare that to buying a new car.
The following 3 users liked this post by Unhingd:
JgaXkr (01-09-2021), odurandina (01-11-2021), scm (01-09-2021)
Old 01-09-2021, 01:20 PM
less than 6 months ago it was all 6 injectors to the tune of $4k
six Audi's and a Lexus I've never had issues like this under 60k miles.
it's clear the engineering went into the body, chassis and exhaust - the engine compartment is a mess.
Old 01-09-2021, 01:23 PM
sov211's Avatar
I have to ask: what fuel and what oil and what oil change intervals have been used consistently in this engine? These are crucial factors for gasoline direct injection (GDI) engines, and the issues of injectors and timing chains is not by any means limited to Jaguars.
Old 01-09-2021, 01:31 PM
5-7k intervals for service
nor worried about timing chain tensioners (I had a v8 Audi s4) - car will be gone before they're issues.
Old 01-09-2021, 01:55 PM
I always use premium gasoline (91 RON + BGK44
  #28
Old 01-10-2021, 07:01 PM
BritCars's Avatar
Sorry to hear about the issues. Water pumps unfortunately seem to be prone to failure/leaking over time. And all manufacturers are using more plastic parts and hoses in the cooling systems which eventually go brittle and fail. Your car is prob pushing 7 years old so it's in the zone that becomes an issue.
If it were me I'd be thankful I was all over it, aware of the issues and didn't overheat it. Would get them to replace all plastic cooling system parts while they are in there (crossover pipes, hoses, header tank and cap etc) and enjoy many more years of happy motoring
sov211 (01-10-2021)
Old 01-11-2021, 01:42 PM
odurandina's Avatar
Originally Posted by BritCars
Presumably an XF if it's 2012? So not quite the right section of the forum. You should repost in the X250 section.
Yes, an XF sorry for posting here.
For future reference are the 5.0XF and F Type engines similar?
Don't drive it!!!! Seriously. If it's losing a quart in 10 miles, it's a serious leak. It could easily dump coolant and overheat the engine - and that is likely death to your engine (the aluminum block doesn't take well to overheating). And a replacement engine is >>value of the car...
Thank you. It's over at Dana's indy shop in Upton Mass (now) getting fixed.
aeginc77
03-10-2021 04:06 PM
TheClown
E-Pace
11-25-2019 08:22 AM
4litre
09-13-2016 02:46 PM
jahummer
25
04-11-2013 06:57 AM
newjagowner
10-05-2012 04:44 PM
Quick Reply: The case of the disappearing coolant
