Center Brake Light Fuse or Relay?
I have a 2014 F-Type V8S, and was having some issues with a couple of dead LEDs on the center rear brake light. I since bought a new OEM replacement and replaced the unit. Now neither the old or new light work at all. The wire and connector look fine and the pins aren't bent.
Is there a fuse or relay somewhere for the middle brake light? I can't find any mention in the fuse listing.
Not sure whats your problem, but can you tell me how you got the light off and how the wires connect to it, i want to tap into that wire to add a F1 style rear brake light under my rear diffuser , would you have a picture of the connections on the old light you took off
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1163/jag_x152_rear_brake_connector_2_4b7532d31fd5de0559269eda831069c27be3e116.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1910x1409/jag_x152_rear_brake_connector_1_72c0f7e606ef21a9875fbef6b587e1fc25d05406.jpg)
There is no fuse or relay. Its run off a solid state module. Wiring goes straight to central junction box. I would check your wiring and see if the signal is getting to the light when brake applied. If its only the high mount, the brake switch would be fine.
Thanks. Since both other brake lights still work, it must be the wiring or connector. Hope I can track down the issue without having to disassemble too much.
Famous Jerry
07-13-2013 06:17 PM
