Center Console Vents!
When the ambient air is cooler than the temperature setting, for instance first thing in the morning, the car will send out heat and the vent stays down.
Once a/c is required, or if the a/c is off, and the car attempts to cool down the interior, the vent raises.
This is with respect to my car.
Lawrence.
Lawrence.
Ggraddy (05-02-2015)
Lawrence.
Lawrence.
When the A/C is on auto, once it reaches the desired temp., does the intensity reduce or it starts blowing wormer air at the same intensity?
It drives me crazy that mine starts blowing wormer air once it reaches desired temp and the dealer tells me it's normal.
I find the system holds temp better if you lock in recirc mode by holding the recirc button for five seconds, then just use the manual fan control on a low to medium speed. You can still pick whatever temp you like, and the fan will still speed up sometimes. Pure auto mode isn't very effective at holding a temp.
Ggraddy (05-03-2015)
Probably in a week or so we'll have some warmer days to test how it behaves and it will be a month or so before we get hot and humid weather that would allow me to test out the recirculating system.
I'll let you know.
Lawrence.
HTH.
Maybe I'm misreading this, but that's what climate control does. Once the cabin reaches the set temperature it backs off the aircon (or the heating, if you're driving in cold conditions) to maintain the set temperature. It will then try to balance cold and warm air flow. If the sensor or control circuitry and actuators are faulty the system may not be able to hold a steady temperature. In which case the cabin temperature will vary. But the air coming out of the vents is going to change temperature.
HTH.
HTH.
On my F Type, as soon as it reaches 70 degrees lets say, it immediately starts blowing, at the same intensity, air from the outside. It also smells like condensation or moisture on the ducts.
It's a continuous process to where i either freeze or sweat
It was only in the mid 70's today, but I kept the windows up for awhile and the a/c on ..
With the car sitting in the Sun the air come out very cold at first as you would expect, and leveled down over time to just cool.. the fan on auto slowed down as well. No warm air at any point.
When it gets hot and humid, I'll try it on re-cycle to see if any difference.
Lawrence.
Lawrence.
Ggraddy (05-05-2015)
