Center Vent Repair Cost?
Hi All,
I have a tentative deal on a 2014 F-Type S, with the only known issue being the central vent rising intermittently.
The car has 45,000 miles on it and it appears to be out of warranty.
Has anyone had to pay to have this fixed out of warranty? Are we talking $500, $1000 or more to resolve at a dealer?
Looking to close the deal this week, or walk away. So any quick responses would be greatly appreciated.
Do you know if you can just set it to stay open?
Just so you know...the vent is supposed to rise intermittently. If the auto temp is set at (or above) the ambient temp, the climate control stays off and the vent will not raise up. If it gets hot and the car needs to cool the interior to the set temp, the vent will then raise. In Florida winter the vent pretty much stays down for me. If that is the behavior that you are witnessing, then it is completely normal and as designed.
Christopher G. Erckert (07-06-2018)
As it is an early model, then there was a known fault that matches your description. My 2015 went in twice to get it resolved. The first time was a software change which didn't resolve it. The second they swapped out the entire vent assembly for a revised part which did resolve it.
The part you need depends on the colour of your vents (the plastic bits) - up till 2016 there were only two options: black or graphite (grey). The black part is T2R17443PAJ, and graphite is T2R17443LMF. Cost is £190 in the UK, and it takes about an hour to swap with basic tools (plastic pry bars and a torx screwdriver).
The following 3 users liked this post by xdave:
The following 2 users liked this post by DJS:
Arne (07-05-2018),
As it didn't affect every car it is probably similar to the issues they still have with the rear sun blinds on the XJ models since 2003. On many, it seems particularly in the UK climate, if they are not raised and lowered about once a week they eventually start to bind and overcome the motor. Some people don't use them for six months though and they work first time.
The following 2 users liked this post by xdave:
Christopher G. Erckert (07-06-2018),
DJS (07-05-2018)
I have the car scheduled to be inspected by the local dealer, before I fly up to collect the car (car is in Michigan, I'm in Louisiana).
I told the dealer, I wanted;
- A complete inspection
- A complete copy of the options list
- A list of the next 12 months o service items.
Anything else I should explicitly ask them to do since I'm not sure I will gather much from a quick test drive? After which, I'd be closing the deal and heading south for a 1,000 mile road trip home.
SansuiMan
01-27-2018 12:06 PM
