Ceramic Brake Pads
Ceramic brake pads...
Anyone have to replace a set yet? I'm guessing no. The car hasn't been out that long. I am retiring the F-type from track duty (I never intended it to be track toy but it's addicting to throw the car around). After four track days I believe I have diminished the time I have left on these pads significantly. I'm guessing those track days are about to become pricey (as are all track days).
MC
2015 F-type R
1995 Mazda Miata #02
2010 Cadillac Escalade
1996 Acura NSX-T sold
2008 Corvette Z06 sold
MC
2015 F-type R
Would you be able to share what the Centric Posi Quite part number is for front and rear? Are you just doing Posi-Quiet front or front/rear?
Just as a side note I bought my 15 pre-owned with only 5200 miles on the clock. A week into owning it I started getting a shudder from the front wheels when braking pretty much self diagnosed as a warped rotor. Then about a week later I was poking around the nav system in the car and found "previous destinations" one of which was Laguna Seca Mazda raceway. LOL probably was the beginning of the end of the factory pads and rotors.
These are the ones I found for the front. I called Stop-tech and this was the number they said I needed. I have not looked into the rears as of yet. Hope that helps.
Amazon.com: Centric Front Brake Pad 104.17500: Automotive
Brake Pads Posi-Quiet Metallic w/Shims R, V8 S; Iron Discs; 380mm Front & 376mm Rear Discs Front 104.17500
Brake Pads Posi-Quiet Metallic w/Shims R, V8 S; Iron Discs; 380mm Front & 376mm Rear Disc Rear 104.17530
I looked up the pads on the Centric site. Unfortunately for me these are the metallic and not ceramic pads. Hopefully Centric will release Posi-Quiet Ceramic pads.
They *do* make ceramics for the BASE F-Type fronts: 105.17510
#30
#31
I run Hawk performance ceramics on my Corvettes and ran EBC ceramics on the Ferrari F430 I used to own. For a street car the braking performance is just fine. On the track, yes it may be different although I had no degradation coming down from 120-140 after 5 lap intervals at Talladega with my C6 Corvette equipped with the Hawk ceramics. To each their own. I hate cleaning up brake dust every time I drive.
#32
firstchoice
10-11-2015 08:15 PM
