ceramic brake retrofit
Old 10-15-2020, 03:52 AM
JacksonvilleJag's Avatar
Does this help?
  #162
Old 10-16-2020, 06:39 AM
BrodieH's Avatar
Originally Posted by JacksonvilleJag
Does this help?
Unfortunately no, that doesn't help. I need a much more detailed wiring diagram such as this, but for the F type. This diagram is for the XF, but its handbrake system is different with only one motor. Thanks for trying though. If anyone else has anything please do share. Thanks
  #163
Old 10-16-2020, 06:47 AM
BrodieH's Avatar
Does this help?
  #164
Old 10-16-2020, 04:21 PM
OzXFR's Avatar
Received 3,216 Likes on 2,371 Posts
Get yourself a copy of my Workshop Manual (for a MY2015 coupe V6S RHD but most of it applies to most F-Types) here: https://www.dropbox.com/s/d52ciochjn...anual.pdf?dl=0
The last chapter is the detailed wiring diagrams, and the park/emergency brake shows on page 28,313. At least on my copy which has one or more extra pages so on the Dropbox copy it should be around page 28,310.
  #165
Old 10-18-2020, 12:14 PM
BrodieH's Avatar
ok thank you, that sounds great. Ill keep you posted on if i find what i need.
  #166
Old 10-18-2020, 01:09 PM
BrodieH's Avatar
i have had a good look through your pdf and cannot find what im looking for unfortunately. You say your document has extra pages, so maybe this is one of them, in which case please send a screenshot. On page 28314 of my document, it shows where the module receives power from, but i need the detailed diagram of all of the connections to and from the parking brake module, motors, etc. Apologies if im being blind or stupid and missed it. Thanks
  #167
Old 10-18-2020, 04:49 PM
OzXFR's Avatar
Nup, it can't be on the extra pages, they are just details specific to my car such as the Topix build sheet.
I know SFA about wiring and electrical stuff so I can't tell what the last chapter - wiring diagrams - does or doesn't show in sufficient detail, but there are at least two mentions of the park brake in there. Keep looking through those pages real close and you might find what you are after!
  #168
Old 10-19-2020, 07:40 PM
DJS's Avatar
DJS
DJS is offline
Received 2,109 Likes on 1,408 Posts
These diagrams are difficult to read - chances are it’s there, and you’re not stupid. Only have my iPad right now, but I’ll see if I can find it...
  #169
Old 10-19-2020, 08:02 PM
DJS's Avatar
DJS
DJS is offline
P. 28234...
OzXFR (10-19-2020)
  #170
Old 10-26-2020, 07:45 PM
BrodieH's Avatar
Originally Posted by DJS
P. 28234...
perfect, thanks!
  #171
Old 08-16-2021, 08:43 AM
Guardian's Avatar
Time to refresh this topic a little bit as I am looking for FRONT calipers upgrade on my MY17 R AWD
Was wondering if it would be possible to use CCM calipers paired with stock 380mm steel rotors with just replacement pads dedicated to steel rotors?
Reason I ask: CCM's are direct bolt-on in front without necessity of using adapters + aftermarket calipers.
  #172
Old 08-16-2021, 09:25 AM
jahummer's Avatar
Received 2,375 Likes on 1,488 Posts
As long as the diameter and thickness match and pad material for metal rotors, there’s no difference in the caliper. So yes, is the answer.
  #173
Old 08-16-2021, 11:39 AM
Guardian's Avatar
what is the diameter and thickness of CCM rotors?
wonder if there are any suitable pads dedicated to steel rotors in production?
  #174
Old 08-16-2021, 12:35 PM
lizzardo's Avatar
The diameter is definitely different. Steel is 380, but I think the CCM is 405 or so.
  #175
Old 08-16-2021, 02:42 PM
scm's Avatar
scm
scm is online now
Received 1,465 Likes on 1,110 Posts
I believe not all 20" wheels fit over the CCM brakes. Or did I imagine that?
  #176
Old 08-16-2021, 06:12 PM
OzXFR's Avatar
You didn't imagine it, only two types of OEM F-Type wheels (both 20") fit over the CCM front brakes.
But of course I can't remember exactly which ones and I'm too lazy to search!
  #177
Old 08-17-2021, 01:30 AM
Guardian's Avatar
How about Gyrodynes...with 15mm spacers
  #178
Old 08-17-2021, 02:30 AM
OzXFR's Avatar
Maybe, dunno, why don't you try it?????
But I got off my lazy ****, did some searching and found the two wheels which go with the CCM brakes - style 5040 AKA Storm and style 1041 AKA Maelstrom.
  #179
Old 08-17-2021, 02:39 AM
Guardian's Avatar
Because I don't want to spend $$$ on the project which may not work
  #180
Old 08-17-2021, 03:18 AM
OzXFR's Avatar
I was only joshing!
Maybe I should start using emoticons.
Quick Reply: ceramic brake retrofit
