Unfortunately no, that doesn't help. I need a much more detailed wiring diagram such as this, but for the F type. This diagram is for the XF, but its handbrake system is different with only one motor. Thanks for trying though. If anyone else has anything please do share. Thanks
Get yourself a copy of my Workshop Manual (for a MY2015 coupe V6S RHD but most of it applies to most F-Types) here: https://www.dropbox.com/s/d52ciochjn...anual.pdf?dl=0
The last chapter is the detailed wiring diagrams, and the park/emergency brake shows on page 28,313. At least on my copy which has one or more extra pages so on the Dropbox copy it should be around page 28,310.
ok thank you, that sounds great. Ill keep you posted on if i find what i need.
i have had a good look through your pdf and cannot find what im looking for unfortunately. You say your document has extra pages, so maybe this is one of them, in which case please send a screenshot. On page 28314 of my document, it shows where the module receives power from, but i need the detailed diagram of all of the connections to and from the parking brake module, motors, etc. Apologies if im being blind or stupid and missed it. Thanks
Nup, it can't be on the extra pages, they are just details specific to my car such as the Topix build sheet.
I know SFA about wiring and electrical stuff so I can't tell what the last chapter - wiring diagrams - does or doesn't show in sufficient detail, but there are at least two mentions of the park brake in there. Keep looking through those pages real close and you might find what you are after!
Time to refresh this topic a little bit as I am looking for FRONT calipers upgrade on my MY17 R AWD
Was wondering if it would be possible to use CCM calipers paired with stock 380mm steel rotors with just replacement pads dedicated to steel rotors?
Reason I ask: CCM's are direct bolt-on in front without necessity of using adapters + aftermarket calipers.
I believe not all 20" wheels fit over the CCM brakes. Or did I imagine that?
You didn't imagine it, only two types of OEM F-Type wheels (both 20") fit over the CCM front brakes.
But of course I can't remember exactly which ones and I'm too lazy to search!
Maybe, dunno, why don't you try it?????
But I got off my lazy ****, did some searching and found the two wheels which go with the CCM brakes - style 5040 AKA Storm and style 1041 AKA Maelstrom.
