Ceramic Brakes
Old 09-07-2018, 02:38 PM
Blue Jag 2017's Avatar
I think the option to convert it to ceramic brakes after I buy it, is out of the question.
The whole brake system is different, even the parking brake in the CCB there are separate calipers for this!...
Old 09-08-2018, 11:16 AM
Stwsam's Avatar
Do not fear the CCB. Those that do, have not had them. Once you have them, at least for me, it saddens me to think that all future cars I own will not likely have them and braking will be a let down. If you truly enjoy driving, they are the pinnacle in my experience. Truly, if you broke a rotor, the replacement is not cheap, although more and more rebuilders exist as the platform is Brembo so the more that exist, the more of a commodity they "may" become. Noise, never heard it. Even if I did, it would be from dirt in the system, not the friction in the system. Again, do not fear the CCB, you will be thrilled if you can land the correct car for you with CCB!
The following 2 users liked this post by Stwsam:
ndabunka (09-12-2018), usgpru27 (09-08-2018)
Old 09-08-2018, 06:01 PM
usgpru27's Avatar
100% agree... Love the as well. Do just need to use caution for a millisecond when its raining really hard. Meaning you have put pressure on the pedal nut just the weight of your foot. And the no brake dust... heaven!
Old 09-09-2018, 12:48 PM
I agree although I haven't tried it, I have only tested the normal brakes in a demo f-type and I can tell you that after using them hard (even for a short period), they "suck"...
Not to mention the dust and the noise... horrible!!
You buy $110,000 car and you don't want pay an other 10??? I really don't understand...
I don't fear the CCB, a car with this performance should have it as "standard"! period!
But again I pay the price by waiting too long to find it...
Old 09-12-2018, 03:50 PM
ndabunka's Avatar
Most of the F-Types with the Carbon were from $130 (R Model) to $160K (SVR) new so the resale will be higher than the $110K vehicles as well. Watch the off lease auctions in about the middle of '19 to find them coming off lease. You should be able to get a '16 R with carbon then for around $75K I would figure. If you want a '17 you may have to wait another year.
Old 09-12-2018, 05:02 PM
the problem is mainly to find a car with CCB, not the value...
Old 09-12-2018, 08:59 PM
usgpru27's Avatar
For a range I just purchased my MY17 for 76K wth 10,000 miles CPO
  #28
Old 09-13-2018, 11:12 AM
Good price if it was in a good condition!! Lucky you!
Old 09-13-2018, 02:36 PM
Stwsam's Avatar
I have the parts list. the work is so straight forward, just like any brake job. The only not bolt on, bolt off was the front and rear dust shields are different. The are quite large because the shroud the bottom of the rotor to protect from debris. The standard shields are so small, I am not even sure how to describe them. To change the dust shields, you remove a screw and drill out two pop rivets. Jag sells the new pop rivets. You then just install new dust shield, ad screw and two pop rivets and your are done. Again, that is the only non- screw. non- bolt or non- snap fitting involved in the job.
If you ask me 100 times the biggest part of the job, bleeding the brakes. Each caliper has two bleed screws and I had me. I tried every trick in the book. It was a royal pain to get all the air out because I was a one man show. Forget asking the wife to sit in the car and pump the brakes for 30 minutes. Before we were married, 38 years ago, no problem. But once they have you, the have you. Did I mention I did this in PA in February in an unheated garage with jack stands? Do not let these boy scouts scare you off what you want.
It seems this is such a mystery conversion. I am a base level mechanic at best.
if interested, email this guy. He can usually come up with a set of discs, calipers, e calipers and the most important item, the rear mounting brackets
The rest of the parts or easily available through dealers.
ukprestigeproducts@gmail.com
  #30
Old 09-13-2018, 03:57 PM
very interesting!!...
So you are saying that you did it to your f-type?
Are you in the US?
what about the rear brakes? because the parking brake has different small black caliper in the CCB.
  #31
Old 09-13-2018, 08:25 PM
ndabunka's Avatar
Delete - That was another member
  #32
Old 09-13-2018, 11:01 PM
usgpru27's Avatar
It was in exceptional shape. Needs the passenger carpet replacement. Has the known failure where it pulls down from the console a touch. Had a dealer installed bra that was of poor quality but did its job. I had a new expel completed on the entire nose and had the entire car ceramic coated. When they did the CPO they put rear tires on it and sent me a picture of the old ones before they were removed. They were not that bad but replaced.
They put it online Friday and I saw it Saturday AM. Did a face time with the salesman and bought it by lunch. They had not even done the CPO yet. Like noted very hard to find a CCB car. Love it!!
ndabunka (09-14-2018)
  #33
Old 09-14-2018, 02:24 AM
mp_x152's Avatar
I was in the same situation, hard to find a CPO with the config I want and CCB. This past weekend I just completed a CCB retrofit. The info Stwsam and others contributed in this thread helped a lot: ceramic brake retrofit. Yes you do need the parking calipers along with additional brackets to mount the parking caliper and the main calipers for the rear. Straightforward job as Stwsam stated, but beware that there are quite a few other parts needed to complete the job properly. I’ll try to post my experience in that other thread tomorrow.
The following 2 users liked this post by mp_x152:
Blue Jag 2017 (09-14-2018), Panthro (09-15-2018)
  #34
Old 09-14-2018, 05:54 AM
KVO's Avatar
KVO
KVO is offline
Indeed a recommended source. Has a website too, but if you need anything special, or not listed, drop him a mail.
  #35
Old 09-15-2018, 11:25 AM
Do you live in USA?
  #36
Old 09-15-2018, 01:47 PM
KVO's Avatar
KVO
KVO is offline
Do you live in USA?
To whom is your question directed to Nick?
  #37
Old 09-15-2018, 02:01 PM
If you can provide me with some photos I will appreciate!
Also, it would be very helpful if you can show me the tools you used for this retrofit!
Thanks a lot!
  #38
Old 09-15-2018, 02:04 PM
Actually I am asking everyone, because I may go to USA this month to purchase the car, so I may pass by to someone who has performed this retrofit to show me the "job"
  #39
Old 09-16-2018, 09:44 PM
mp_x152's Avatar
I'm in the US. The job doesn't require any special tools except maybe the riveter. I'll have to think and list things out when I get a chance.
Blue Jag 2017 (09-17-2018)
  #40
Old 09-17-2018, 08:57 AM
Stwsam's Avatar
picked up rivet tool at el cheapo harbor freight
that was the only special tool I needed.
Car is in Pa. Always welcome an inspection
mikchek
05-08-2019 11:38 AM
Vince Del
08-25-2014 07:18 AM
rogerdodger
06-13-2011 07:29 PM
Ilbella83
05-05-2010 09:24 AM
mitch.thompson
07-17-2009 06:40 AM
Quick Reply: Ceramic Brakes
