Ceramic brakes squeaking
i know ceramic brakes squeak, but they seem to be more noticeable. The car has 20,000 miles. I would not have thought the brakes would be ready to be replaced at this point. Anyone know how long they're lasting or if I should be concerned? Anyone know how much they cost to replace?
Received 3,226 Likes
20,000 miles is around normal for the pads on the iron brakes to wear out, and many find the rear pads are shot at even 10,000 miles, so it wouldn't surprise me at all if the CCM pads are worn out at 20,000 miles.
My copy of the Service Manual shows the following specs for the front CCM brakes (I don't have CCM brakes and it doesn't show the rear specs, go figure!):
Pad thickness new: 14.25 mm / .55"
Minimum pad thickness: 3 mm / .118"
Rotor thickness new: 38 mm / 1.49"
Minimum rotor thickness: 37.5 mm / 1.47".
This tells me that the CCM brakes are designed to wear the pads very quickly and the rotors hardly at all, bit of a no-brainer when you consider the cost of pads vs the cost of rotors.
If you needed pads you'd be notified on the cluster as they have pad wear sensors. I have carbon ceramics as well and a bit over 20k miles and there's plenty of pad left and I do drive like a mental case.
Carbon ceramic squeak A BIT, it is just a part of their characteristics, you can minimize it a bit but you'll never get rid of it. I've worked on porches, Lamborghini, Ferrari, Mercedes, BMW, etc, with carbon ceramic brakes and they all squeak a bit to a certain degree, the squeak will also vary a bit depending on disc and pad temps...
