Certified Jag sold to me with no oil changes for 3 yrs.
My second oil change did not reflect any additional break-in metals.
Carfax did not show any service records. Engine oil analysis was consistent with not having any oil changes for three years.
Oil changes as per Jaguar are required once a year or 16K miles. Jaguar includes free oil and filter changes for three years.
Jaguar dealership service dept. located very close to lease owner.
Oil analysis results. Aluminum=17 normal=9 Iron=31 normal=18 copper=12 normal=3
Normal would be for an oil change at 16K miles. This analysis was done after 1K miles
- Beverly Hills lease (same as my F) implies a more mature sedate driver, even if less conscientious.
- Lower than factory change interval on miles. The calendar change seems self-serving from the oil manufactyrer perspective - I checked the bottles I have and none have a use-by date.
Oil in the bottle doesn't oxidize and oil in the bottle does not have moisture, unburned fuel, acids from incomplete combustion, etc.
Those things said, I also would consider buying the car were I looking for one like it. I'm still curious about the certification report. I've been told but haven't confirmed that failure to get service on schedule (+/1 one month, if going by time) invalidates the included (not actually "free") scheduled service.
The CPO literature lists165 things inspected for certification, but not all inspected things are warrantied under the CPO program, like paint. Only "sudden mechanical or electrical failure" is expressly warrantied. So even if they actually need to check the service history by procedure, doesn't mean certification would have teeth if nothing is clearly broken.
Also, technically, its ok not to have service records according to Jaguar, "Some owners may wish to have their engine oil changed more frequently than required, should the vehicle have a high proportion of short journeys or operate in severe conditions. These extra services may be performed on a customer pay basis and the service interval indicator will not be reset."
Also technically, one would hope a lease agreement would require either dealer or customer performed required or better oil services, but, realistically, probably not.
And also, technically, if you don't present the car within 30 days of the anniverisary of the in-service date, the included service is denied and will always appear as missed in the computer because it is a time-limited coded service. But that doesn't prove the car never had an oil change.
If I ever leased a car, I would pay for a change if I missed the 30 day window. And there is no way I would wait a year change the oil even on lease. Not all leasors are resigned to turn the car in, and not all are resigned to boofing the next owner just because.
#28
I encountered this situation with my CPO coupe, purchased from a SoCal dealer (perhaps the same one you bought from). Missing service (thankfully just one). Mostly I was annoyed that I couldn't get them to perform the missed maintenance, as it was outside the 30-day window, and the only solution offered to me was to do the next scheduled service early.
My takeaway is that CPO has value for the extended warranty, but the rest is just marketing. I wouldn't trust the "inspection" or any implications that the car is automatically in better condition than a non-CPO vehicle.
This was not a mature driver- they lease cars to have someone to talk to in the service dept.
This was someone oblivious to caring for a car. 12000 miles of idling on the 5 could be like 36,000 miles without an oil change in normal cities. Check the brake pads and rotors, they will provide the right clues.
SinF (03-04-2020)
#30
#31
Frank here my16 s coupe storm grey with brogue interior ivory stitching performance seats, when I purchased my jag last year with 30,000 miles. They replaced rear tires, brake pads and rotors. I understand that if brake pads are replaced they also replace the rotors.
Frank Hudson valley NY
#32
Carbuff2 (03-04-2020)
#33
Queen and Country (03-04-2020)
#34
Well, you know the brakes were used a lot, but i've followed many cars whose drivers used the brakes nearly all the time - bump in the road - brake, oncoming car - brake, slight bend in the road - brake. None of those cars were being thrashed, in fact, they were holding me up! I use my brakes a lot less, I prefer to judge my speed and adjust according to the conditions, so no need to use the brakes, which anyway just wastes fuel!
#35
#36
This car was used to commute and spent a lot of time stuck in traffic- and stop and go driving.
There is no way to avoid it in SoCal. It certainly was not used just to cruise on the weekends.
Also why was the pads changed and not the oil!!!
Clearly this was an appliance to someone in disposable SoCal culture, and not an exotic purchase as it would be to us.
So lets be helpful. If you paid a premium for it, peruse your legal recourse, being mindful of your own time. There are lawyers who specialize in misrepresentations/ deception. (your claim is that this is not certified- scheduled maintenance was not done- The onus is on them to prove the oil was changed) Yes get that $5k back, that is the difference between a cert car and non-certified car.
Its not the end of the world, you can undo what little damage may have been done, namely sludge. One other clue that would be most helpful is how much oil was extracted when it finally got an oil change.
#37
So this tells you a few things.
He said the dealear did change the oil at 12K, so the only miss is by calandar date, not by mileage. And even that is only a guess, since the oil could have been changed, we just don't know. That's no different than the 99.999% of used cars sold without all oil change receipts, except in this one doesn't have enough total miles to worry.
Another thing I would add is that the one year covered changes every 16K miles are not enough. So unless a car has the first 3 annual services plus at least 2 sets of additional oil receipts per year, then it was not properly maintained IMO. At least this car has low miles, a car with normal miles and only the 3 annual changes should definitely be avoided.
woodturner
11-04-2017 12:01 PM
Tahoe Dave
08-31-2014 09:38 AM
