Changing headlight bulbs - stuck at the metal cable harness
If you've been successful in removing the bulb covers, as it seems you are at this point, trace the connection-end of the braided connector with your fingers for the attachment clip. It is either on the side of the connector or at the top of the connector. Though I had the dealer do the install (since I couldn't get my hands into the area sufficient to pull out the bulb without either removing the headlamp assemblies or the components around them (p/s reservoir and relay box), the connector that attaches to the bulb/ignitor assembly likely has a release clip that is either pressed or lifted. ( In some cars, the connector simply pulls off, but I doubt that that is the case with the Jag.) In any event, once you get the sense of how the clip works, it is very easy to release. No massive torque-down here.
Wish I could help further. Keep us posted.
domino_z (11-27-2015)
I believe he is asking how to release the braided connector from its bulb/ignitor assembly, not how to separate the bulb from the ignitor (which is, as you indicate, one assembly).
Yep I'm trying to remove the braided cable from base of bulb
It is a push clip but it just won't budge. May try wedging a small toothpick under the clasp and pulling
Re working on the fuse box side, you can remove the two bolts holding the fuse box in place and rotate it away to give same straight access as passenger side
Are these the bulbs you are putting in
Whatever you are putting in, please let us know how they compare to OEM
That the connector "just won't budge" tells me that you are either not releasing the clip sufficiently, or are not applying enough force (though I use that word gingerly here) in pulling off the connector. Though the pins in the ignitor are delicate, both connector and ignitor are at least metal, not plastic--they should be able to take a little tug as long as you are trying to pull the connector straight off, not at an angle.
I found in past connector removals that at times I was "too gentle," fearing breakage of the connector. You might try one last time, pushing in the clip and pulling on the connector in a tad more vigorous fashion. if the connector still won't budge, I'm guessing the clip is not releasing properly. Better think about having the dealer do the install.
