changing wheels/tires with respect to odometer/speedometer
Just a quick question I start to measure my options for winter. I drive a V6S that came with 19" wheels. The stock tire sizes are 245/40 on the front and 275/35 on the back.
If I were to drop down to 18" wheels for winter tires, would I be fine if I just shopped for the same size tires that come on 18-inch F-Type wheels? I know that if you wind up changing the overall wheel+tire diameter that your odometer becomes inaccurate.
So, the same question put differently: are factory mounted 19s and 18s interchangeable, or is a car delivered with 19s only calibrated for that particular wheel+tire diameter?
There are 245/45-18 snow tires. You might consider buying 2 pairs of front 18" wheels and mount those on all 4 corners. Those narrower tires will work far better than the 275s in snow.
Looks like the best of the class for 245/45-18 would be Sottozeros.
I'm still not sold on investing in new wheels for a lease. I know that 275s on the rear could be a detriment but I'm hoping it would be overcome by having AWD.
Agreed. Unless you are keeping the car after a lease, not worth it to buy much of anything for the car, and the AWD will more than make up for the wider lower profile tires.
Instead of a new post, I will use OP! Thanks! =)
I am at 10K. I think I need new rear tires (tread is about at the marker). What are other people's wear-time like? Trying to figure out what to do prior to a 4000 mile road trip. I think new rear tires for the trip rather than spending 3 weeks waiting for them to wear while being nervous?
Monsters of Grip: Nine Summer-Performance Tires Tested - Comparison Test - Car and Driver
2) any opinion of replacing rear with PSS and wait on the Pzeros to wear down in front? Idea of changing 4 tires 10 months after it being brand new feels.... Meh.
1) are the pilot super sport the hands down best? C&D thinks so:
It's generally recommended not to mix and match tires, but if you keep the same tires on an "axle", a good driver can acclimate quickly. With P-Zeros on just the front, there will be a slight understeer tendency.
The PSSs appear to be widely acclaimed as the best for street use. There are others including another Michelin model are stickier for track use, but all at the expense of tread life.
Alan Stoldt
04-01-2016 02:49 PM
